Arbitrary Scaling of Gizmo Plot
// This section of code is PART of the Gizmo window creation routine.
// It sets up clip planes to prevent data that extends beyond the xyz range of the Gizmo cube from being displayed.
// The first line sets things up for non-unity scaling, if desired later.
ModifyGizmo setDisplayList=1, opName=scale0, operation=scale, data={1,1,1} // enables non-even scaling (default is cubic)
ModifyGizmo setDisplayList=2, opName=enable0, operation=enable, data=12288 // enables clip plane 0
ModifyGizmo setDisplayList=3, opName=enable1, operation=enable, data=12289 // enables clip plane 1
ModifyGizmo setDisplayList=4, opName=enable2, operation=enable, data=12290 // enables clip plane 2
ModifyGizmo setDisplayList=5, opName=enable3, operation=enable, data=12291 // enables clip plane 3
ModifyGizmo setDisplayList=6, opName=enable4, operation=enable, data=12292 // enables clip plane 4
ModifyGizmo setDisplayList=7, opName=enable5, operation=enable, data=12293 // enables clip plane 5
ModifyGizmo setDisplayList=8, opName=ClipPlane0, operation=ClipPlane, data={0,0,0,1,1} // clips at bottom
ModifyGizmo setDisplayList=9, opName=ClipPlane1, operation=ClipPlane, data={1,0,0,-1,1} // clips at top
ModifyGizmo setDisplayList=10, opName=ClipPlane2, operation=ClipPlane, data={2,1,0,0,1} // clips at xmin
ModifyGizmo setDisplayList=11, opName=ClipPlane3, operation=ClipPlane, data={3,-1,0,0,1} // clips at xmax
ModifyGizmo setDisplayList=12, opName=ClipPlane4, operation=ClipPlane, data={4,0,1,0,1} // clips at ymin
ModifyGizmo setDisplayList=13, opName=ClipPlane5, operation=ClipPlane, data={5,0,-1,0,1} // clips at ymax
ModifyGizmo setDisplayList=14, object=surface0 // actual surface
ModifyGizmo setDisplayList=15, opName=disable0, operation=disable, data=12288 // disables clip plane 0
ModifyGizmo setDisplayList=16, opName=disable1, operation=disable, data=12289 // disables clip plane 1
ModifyGizmo setDisplayList=17, opName=disable2, operation=disable, data=12290 // disables clip plane 2
ModifyGizmo setDisplayList=18, opName=disable3, operation=disable, data=12291 // disables clip plane 3
ModifyGizmo setDisplayList=19, opName=disable4, operation=disable, data=12292 // disables clip plane 4
ModifyGizmo setDisplayList=20, opName=disable5, operation=disable, data=12293 // disables clip plane 5
// Procedure manually sets the XYZ range of the Gizmo plot
// NOTE: one can return to autorange (i.e., plotting full range of data) with:
// ModifyGizmo ScalingMode=2
Proc SetGizmoScales(xMin, xMax, yMin, yMax, zMin, zMax)
Variable xMin, xMax, yMin, yMax, zMin, zMax
ModifyGizmo setOuterBox={xMin,xMax,yMin,yMax, zMin, zMax}
ModifyGizmo update=2 // NOTE: doesn't work with update=1
EndMacro
// Function allows Gizmo display cube to be set to something other than cube.
// XY aspect ratio can be set to match displayed xy data range.
// Z aspect ratio can be set arbitrarily anywhere from 0-1
Function GizmoRescale()
Variable zAxisScaling = 1
Variable xyScalingMode
Prompt zAxisScaling, "Scaling Factor for z-axis (default=1)"
Prompt xyScalingMode, "XY axes scaling", popup, "None (default);Scaled to displayed xy data range"
DoPrompt "Gizmo Scaling Parameters", zAxisScaling, xyScalingMode
if(V_Flag)
return -1 // user cancelled
String Cmd
Variable xAxisScaling = 1
Variable yAxisScaling = 1
Variable diag
// want to scale xy plane to data's aspect ratio
if(xyScalingMode==2)
NVAR /Z aspectRatio = root:gGizmoXYaspectRatio // displayed aspect ratio already stored as global variable
if( !NVAR_Exists(aspectRatio) )
Variable /G root:gGizmoXYaspectRatio = 1
print "Warning: unknown xy aspect ratio - setting to unity"
if(aspectRatio>1)
yAxisScaling = aspectRatio
xAxisScaling = 1/aspectRatio
diag = sqrt(xAxisScaling^2 + yAxisScaling^2) // this scaling always shrinks - compensate
xAxisScaling *= sqrt(2)/diag
yAxisScaling *= sqrt(2)/diag
// create actual display list (order is important)
sprintf Cmd, "ModifyGizmo setDisplayList=1, opName=scale0, operation=scale, data={%f,%f,%f}", xAxisScaling, yAxisScaling, zAxisScaling
Execute Cmd
