Load Patchmaster 2X90 File
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
// Procedures to load a Patchmaster 2X90 file.
// The file format is unconventional as it contains both spaces and commas
// and, more problematic, uses letters instead of exponents for numbers.
// For example:
// 4.3765M means 4.3765E+6
// 124.10m means 124.10E-3
// -10.084p means -10.084E-12
// 255.44f means 255.44E-15
// These procedures were written for a particular user's Patchmaster which
// started like this:
// Series_1_1
// Sweep #, Mean-80[A], Mean80[A], Timer[s], R-series[Ω], C-slow[F]
// 1, -10.084p, 255.44f, 124.10m, 4.3765M, 10.982p
// <more data here>
// If your file has a different organization, you will need to customize
// these procedures.
Menu "Load Waves"
"Load Patchmaster 2X90 File...", LoadPatchmaster2X90File("", "", 0, 1)
// FixText(textIn)
// Returns cleaned up version of text without bad line breaks.
// To keep it simple, this routine assumes that each original line of data
// has been split into exactly two lines.
// We also assume that the terminator is CRLF.
// We also assume that there is a terminator for the last line of the file.
// NOTE: You will need to tweak this for your situation
static Function/S FixText(textIn)
String textIn
String textOut = ReplaceString(" ", textIn, "") // Remove spaces
textOut = ReplaceString(",", textOut, "\t") // Replaces commas with tabs which make a more readable file
textOut = ReplaceString("f", textOut, "E-15", 1) // Replace f (femto)
textOut = ReplaceString("p", textOut, "E-12", 1) // Replace p (pico)
textOut = ReplaceString("n", textOut, "E-09", 1) // Replace n (nano)
textOut = ReplaceString("u", textOut, "E-06", 1) // Replace u (micro)
textOut = ReplaceString("m", textOut, "E-03", 1) // Replace m (milli)
textOut = ReplaceString("k", textOut, "E+03", 1) // Replace k (kilo)
textOut = ReplaceString("M", textOut, "E+06", 1) // Replace M (mega)
textOut = ReplaceString("G", textOut, "E+09", 1) // Replace G (giga)
textOut = ReplaceString("T", textOut, "E+12", 1) // Replace T (tera)
textOut = ReplaceString("P", textOut, "E+15", 1) // Replace P (peta)
return textOut
static Function/S GetColumnInfoStr() // Sets wave names
String columnInfoStr = ""
columnInfoStr += "N='Sweep';"
columnInfoStr += "N='MeanMinus80C';"
columnInfoStr += "N='MeanPlus80C';"
columnInfoStr += "N='Timer';"
columnInfoStr += "N='RSeries';"
columnInfoStr += "N='CSlow';"
return columnInfoStr
// LoadPatchmaster2X90File(pathName, fileName, autoLoadAndGo, createTable)
Function LoadPatchmaster2X90File(pathName, fileName, autoLoadAndGo, createTable)
String pathName // Name of an Igor symbolic path or ""
String fileName // Name of file or full path to file
Variable autoLoadAndGo // If non-zero, loads with default names, overwriting any pre-existing waves with those names
Variable createTable // 0=no table; 1=create table
Variable refNum
// First get a valid reference to a file.
if ((strlen(pathName)==0) || (strlen(fileName)==0))
// Display dialog looking for file.
String fileFilters = "Text Files (*.asc,*.txt,*.dat,*.csv):.asc,.txt,.dat,.csv;"
fileFilters += "All Files:.*;"
String promptStr = "Choose Patchmaster 2X90 Data File"
Open /D /R /P=$pathName /F=fileFilters /M=promptStr refNum as fileName
fileName = S_fileName // S_fileName is set by Open/D
if (strlen(fileName) == 0) // User cancelled?
return -1
// Open source file and read the raw text from it into a string variable
Open/Z=1/R/P=$pathName refNum as fileName
if (V_flag != 0)
return -1 // Error of some kind
FStatus refNum // Sets V_logEOF
Variable numBytesInFile = V_logEOF
String text = PadString("", numBytesInFile, 0x20)
FBinRead refNum, text // Read entire file into variable.
Close refNum
// Fix the text
text = FixText(text) // Create cleaned-up version of the file
// Write the cleaned up text to a temporary file
String tempFileName = fileName + ".noindex" // Use of .noindex prevents Spotlight from indexing the file. Otherwise we get an error when we try to delete the file because Spotlight has it open.
Open refNum as tempFileName
FBinWrite refNum, text
Close refNum
// Load the temporary file
int dataStartLine = 2
String columnInfoStr = GetColumnInfoStr() // Sets wave names
if (autoLoadAndGo)
LoadWave/J/D/A/O/E=(createTable)/Q/L={0,dataStartLine,0,0,0}/B=columnInfoStr/P=$pathName tempFileName
LoadWave/J/D/E=(createTable)/Q/L={0,dataStartLine,0,0,0}/B=columnInfoStr/P=$pathName tempFileName
if (V_flag == 0)
Printf "An error occurred while loading data from \"%s\"\r", S_fileName
Printf "Loaded data from \"%s\"\r", S_fileName
// Delete the temporary file
DeleteFile /P=$pathName tempFileName
