Load Tek ISF File
I recommend that you download the attached file rather than copying this code because I had some formatting problems with the URLs in the comments.
#pragma rtGlobals=3		// Use modern global access method.
// File Loader for Tektronix ISF files
// A Tektronix ISF file is the contents of what a Tek oscilloscope sends in response
// to a WAVFrm? command. See https://www.tek.com/support/faqs/what-format-isf-file
// A Tek ISF file is not the same as a Tek WFM file. There exists a loader for Tek WFM files.
// See https://www.wavemetrics.com/project/LoadTekWaveform.
// It is recommended that you name your Tek ISF files with the ".isf" extension to make
// it clear what kind of file it is.
// The way to determine the header length is to look for the ":CURVE" keyword. It is formatted like this:
//		":CURVE <digit><number>"		.e.g., ":CURVE 41000"
// where <digit> represents the number of digits is the following number and <number> represents the number of
// samples of binary data that follow. In this case, "4" is the number of digits in "1000" and 1000 is the number of samples.
static Constant kHeaderLength = 282				// Length of header in bytes. Empirically determined.
static Constant kWaveDataType = 2				// Single precision floating point
//	LoadTekISFFile(pathName, fileName, createTable, createGraph)
//	pathName is the name of an Igor symbolic path or "".
//	fileName is one of the following:
//		The name of a file in the folder designated by pathName.
//		A partial path from the folder designated by pathName to the file to be loaded.
//		A full path to the file to be loaded.
//		"" to get an Open File dialog.
// Add an item to Igor's Load Waves submenu (Data menu)
Menu "Load Waves"
	"Load Tek ISF File...", LoadTekISFFileMenuItem()
	"Load All Tek ISF Files In Folder...", LoadAllTekISFFiles("", "", 0, 0)
Function/S StripDoubleQuotes(str)
	String str					// A string starting and ending with double quotes
	if (CmpStr(str[0], "\"") != 0)
		return str				// String did not start with double quotes
	Variable len  = strlen(str)
	str = str[1,len-2]
	return str
Structure TekISFHeaderInfo
	Variable encoding			// 0 = binary. -1 = unknown. Currently the only encoding I know about is binary. From ENCDG keyword.
	Variable byteOrder			// 0 = big-endian, 1 = little-endian.  From BYT_OR keyword.
	Variable dataType			// See WaveType for possible values. From BIT_NR and BN_FMT keywords.
	Variable numPoints			// Number of points in waveform. From NR_PT keyword.
	String xUnits				// From XUNIT keyword.
	Variable x0					// From XZERO keyword.
	Variable dx					// From XINCR keyword.
	String yUnits				// From YUNIT keyword.
	Variable yOffset				// From YOFF keyword.
	Variable yZero				// From YZERO keyword.
	Variable yMultiplier		// From YMULT keyword.
EndStructure
Function ExtractISFHeaderInfo(refNum, headerInfo, quiet)
	Variable refNum			// File reference number
	STRUCT TekISFHeaderInfo &headerInfo
	Variable quiet				// 0 - print information about errors
	Variable result = 0
	Variable originalPos
	FStatus refNum
	originalPos = V_filePos
	// Read header string
	String headerStr = ""
	Variable headerStrLength = kHeaderLength
	FSetPos refNum, 0
	headerStr = PadString(headerStr, kHeaderLength, 0x20)
	FBinRead refNum, headerStr
	FSetPos refNum, originalPos
	// Parse header string
	String str
	str = StringByKey("ENCDG", headerStr, " ")
	strswitch(str)
		case "BIN":
			headerInfo.encoding = 0
			break
		default:
			headerInfo.encoding = -1			// Unknown encoding
			result -= 1
			break
	endswitch
	str = StringByKey("BYT_OR", headerStr, " ")
	strswitch(str)
		case "MSB":
			headerInfo.byteOrder = 0
			break
		case "LSB":
			headerInfo.byteOrder = 1
			break
		default:
			headerInfo.byteOrder = -1			// Unknown byte order
			result -= 1
			break
	endswitch
	headerInfo.numPoints = NumberByKey("NR_PT", headerStr, " ")
	headerInfo.xUnits = StripDoubleQuotes(StringByKey("XUNIT", headerStr, " "))
	headerInfo.x0 = NumberByKey("XZERO", headerStr, " ")
	headerInfo.dx = NumberByKey("XINCR", headerStr, " ")
	headerInfo.yUnits = StripDoubleQuotes(StringByKey("YUNIT", headerStr, " "))
	headerInfo.yOffset = NumberByKey("YOFF", headerStr, " ")
	headerInfo.yZero = NumberByKey("YZERO", headerStr, " ")
	headerInfo.yMultiplier = NumberByKey("YMULT", headerStr, " ")
	Variable numBitsPerPoint = NumberByKey("BIT_NR", headerStr, " ")
	String binaryFormat = StringByKey("BN_FMT", headerStr, " ")
	strswitch(binaryFormat)
		case "RI":								// Presumably "real integer"
			switch (numBitsPerPoint)
				case 8:
					headerInfo.dataType = 8		// 8 bit signed integer
					break
				case 16:
					headerInfo.dataType = 16	// 16 bit signed integer
					break
				case 32:
					headerInfo.dataType = 32	// 32 bit signed integer
					break
				default:
					headerInfo.dataType = -1	// Unknown type
					result -= 1
					break
			endswitch
			break
		default:
			headerInfo.dataType = -1			// Don't understand datatype
			result -= 1
			break
	endswitch
	return result
//	LoadTekISFFileDialog(createTable, createGraph)
//	Displays a dialog in which the user can enter parameters.
//	All of the parameters function both as inputs, to preset the dialog values,
//	and as output, to return the values to the calling routine.
//	The function result is 0 if OK or -1 if cancel.
Function LoadTekISFFileDialog(createTable, createGraph)
	Variable &createTable				// Input and output.
	Variable &createGraph				// Input and output.
	if ( (createTable<1) || (createTable>2) )
		createTable = 1
	if ( (createGraph<1) || (createGraph>2) )
		createGraph = 1
	// This is necessary because you can't pass an & parameter to Prompt.
	Variable createTable2 = createTable
	Variable createGraph2 = createGraph
	Prompt createTable2, "Create table", popup "Yes;No"
	Prompt createGraph2, "Create graph", popup "Yes;No"
	DoPrompt "Load Tek ISF File", createTable2, createGraph2
	if (V_Flag != 0)
		return -1			// User cancelled.
	createTable = createTable2
	createGraph = createGraph2
Function LoadTekISFFile(pathName, fileName, createTable, createGraph, quiet, newWaveName)
	String pathName			// Igor symbolic path name or "" for dialog.
	String fileName				// file name, partial path and file name, or full path or "" for dialog.
	Variable createTable		// 1 = Yes, 2 = No, 0 for dialog.
	Variable createGraph		// 1 = Yes, 2 = No, 0 for dialog.
	Variable quiet				// 0 = print diagnostic and error messages, 1 = print error messages only, 2 = do not print diagnostic or error messages
	String &newWaveName		// Output: Name of wave created.
	newWaveName  = ""
	Variable err
	if ( (createTable==0) || (createGraph==0) )
		err = LoadTekISFFileDialog(createTable, createGraph)
		if (err != 0)
			return err
	// This puts up a dialog if the pathName and fileName do not specify a file.
	String message = "Select a Tek ISF file"
	Variable refNum
	Open /R /Z=2 /P=$pathName /T="????" /M=message refNum as fileName	// /T flag presents "All files" in Open File dialog.
	// Save outputs from Open in a safe place.
	err = V_Flag
	String fullPath = S_fileName
	if (err != 0)
		return err			// -1 means user canceled.
	// Load the header information
	STRUCT TekISFHeaderInfo headerInfo
	if (ExtractISFHeaderInfo(refNum, headerInfo, quiet!=2) != 0)
		if (quiet != 2)
			Print "Error while loading header section of the file."
		Close refNum
		return -1
	Close refNum
	switch (headerInfo.encoding)
		case 0:								// Binary
			break
		default:
			if (quiet != 2)
				Print "The file's encoding is unknown. Only binary encoding is supported."
			return -1
	endswitch
	if (quiet == 0)
		Printf "Loading Tek ISF data from \"%s\"\r", fullPath
	GBLoadWave /B=(headerInfo.byteOrder) /A=tekWave /T={headerInfo.dataType,kWaveDataType} /S=(kHeaderLength) /W=1 /U=(headerInfo.numPoints) /Q fullPath
	if (V_flag == 0)
		if (quiet != 2)
			Print "Error while loading binary data section of the file."
		return -1
	newWaveName = StringFromList(0, S_waveNames)
	Wave w = $newWaveName
	SetScale/P x, headerInfo.x0, headerInfo.dx, ""+headerInfo.xUnits, w
	SetScale d, 0, 0, ""+headerInfo.yUnits, w
	// I don't know what headerInfo.yZero is all about (YZERO keyword).
	w = (w - headerInfo.yOffset) * headerInfo.yMultiplier
	if (quiet == 0)
		Printf "Created wave %s, %d points.\r", newWaveName, numpnts(w)
	if (createTable == 1)
		Edit w.id
		ModifyTable format[1]=3,digits[1]=9		// Display time in suitable format.
	if (createGraph == 1)
		Display w
	return 0			// Zero signifies no error.
Function LoadTekISFFileMenuItem()
	String newWaveName
	LoadTekISFFile("", "", 1, 1, 0, newWaveName)
//	LoadAllTekISFFilesDialog(extension, createTable, createGraph)
Function LoadAllTekISFFilesDialog(extension, createTable, createGraph)
	String &extension					// Input and output
	if (CmpStr(extension,".isf")!=0 && CmpStr(extension,"????")!=0)
		extension = ".isf"
		createTable = 1
		createGraph = 1
	String extension2 = extension
	Prompt extension2, "Tek ISF file name extension", popup ".isf;Any extension"
	DoPrompt "Load All Tek ISF Files", extension2, createTable2, createGraph2
	if (V_Flag != 0)
	if (CmpStr(extension2, "Any extension") == 0)
		extension2 = "????"
	extension = extension2
Function LoadAllTekISFFiles(pathName, extension, createTable, createGraph)
	String pathName			// Name of an Igor symbolic folder created by Misc->NewPath
	String extension			// e.g., ".isf". Pass "????" for any extension. Pass "" for dialog.
	if (CmpStr(extension,"")==0 || createTable<1 || createTable>2 || createGraph<1 || createGraph>2)
		if (LoadAllTekISFFilesDialog(extension, createTable, createGraph) != 0)
	if (strlen(pathName) == 0)
		String message
		if (CmpStr(extension, "????") == 0)
			message = "Select a directory containing Tek ISF files with any extension"
			sprintf message, "Select a directory containing Tek ISF files with %s extension", extension
		NewPath/O/M=message TekISFDataPath		// This displays a dialog in which you can select a folder
		if (V_flag != 0)
			return V_flag							// -1 means user canceled
		pathName = "TekISFDataPath"
	Variable err = 0
	String newWaveName
	String fileName
	Variable i = 0
	do
		fileName = IndexedFile($pathName, i, extension)
		if (strlen(fileName) == 0)
			break										// No more files
		err = LoadTekISFFile(pathName, fileName, 2, 2, 1, newWaveName)
		if (err != 0)
			return err
			if (i == 0)
				Edit $newWaveName
				AppendToTable $newWaveName
			if (i == 0)
				Display $newWaveName
				AppendToGraph $newWaveName
		i += 1
	while(1)
LoadTekISFFile.zip (4.11 KB)
