One way of sending mail from IGOR
A quick and direct solution of sending mail is available if you have the base64.xop and SOCKIT files installed, and the server doesn't require secure login. It is also possible to send attachments, but this requires slightly more effort as the attachment needs to be encoded in base64 (which is possible, if I get round to writing it).
Here is some sample code that demonstrates using the SMTP LOGIN protocol (another option may be PLAIN, see http://www.technoids.org/saslmech.html#appA) :
string mailServer = "mail.mymailserver.com"
string username = base64encode("myusername")
string password = base64encode("mypassword")
variable sock		//holds the SOCKIT reference
make/t buf			//holds the output from the SOCKIT connection
sock = sockitopenconnection(mailServer,25,buf,"","",1)	//open a SOCKIT connection to the mail server
sockitsendmsg(sock,"AUTH LOGIN\n")		//SMTP LOGIN, NOT VERY SECURE
sockitsendmsg(sock,username+"\n")
sockitsendmsg(sock,password+"\n")
sockitsendmsg(sock,"HELO whatever.whatever.com\n")		//say HELO to the server
sockitsendmsg(sock,"MAIL FROM: username@mymailserver.com\n")		//say who you are
sockitsendmsg(sock,"RCPT TO: poo@mymailserver.com\n")		//say who the recipient is
sockitsendmsg(sock,"DATA\n")		//start the message
sockitsendmsg(sock,"Subject:test a message\n\n")		//subject line, note double newline is required
sockitsendmsg(sock,"This is a test message\n")		//the message
sockitsendmsg(sock,".\n")		//finish the message and send
sockitcloseconnection(sock)	//close the SOCKIT connection
RGerkin
I'm updating this example with SockIT operations. Also, some mail servers require CRLF in places, or require HELO before AUTH LOGIN. For example, this format will work for Yahoo mail. For servers that require SSL, like gmail, see http://www.igorexchange.com/node/952.
For some reason, this only works without the /q flag in sockitiopenconnection. Maybe printing output slows Igor down enough to let messages get sent before the socket is closed?
// For yahoo, use smtpServer="smtp.mail.yahoo.com"
function email(selfServer,smtpServer,username,password,from,to,subject,message)
	string selfServer,smtpServer,username,password,from,to,subject,message
	make/o/t buf		//holds the output from the SOCKIT connection
	sockitopenconnection /time=1 sock,smtpServer,25,buf	//open a SOCKIT connection to the mail server
	sockitsendmsg sock,"HELO "+selfServer+"\n"		//say HELO to the server
	sockitsendmsg sock,"AUTH LOGIN\n"		//SMTP LOGIN, NOT VERY SECURE
	sockitsendmsg sock,base64encode(username)+"\r\n"
	sockitsendmsg sock,base64encode(password)+"\r\n"
	sockitsendmsg sock,"MAIL FROM:"+from+"\n"		//say who you are
	sockitsendmsg sock,"RCPT TO:"+to+"\n"		//say who the recipient is
	sockitsendmsg sock,"DATA\n"		//start the message
	sockitsendmsg sock,"Subject:"+subject+"\r\n"		//subject line, note double newline is required
	sockitsendmsg sock,message+"\r\n"		//the message
	sockitsendmsg sock,"\r\n.\r\n"		//finish the message and send
	killwaves /z buf
andyfaff
Could one roll it up like:
        string cmd = ""
	sockitopenconnection/q sock,smtpServer,25,buf	//open a SOCKIT connection to the mail server
        cmd += "HELO "+selfServer+"\n"		//say HELO to the server
	cmd += "AUTH LOGIN\n"		//SMTP LOGIN, NOT VERY SECURE
        cmd += base64encode(username)+"\r\n"
	cmd += base64encode(password)+"\r\n"
        cmd += "MAIL FROM:"+from+"\n"		//say who you are
	cmd += "RCPT TO:"+to+"\n"		//say who the recipient is
	cmd += "DATA\n"		//start the message
	cmd += "Subject:"+subject+"\r\n"		//subject line, note double newline is required
	cmd += message+"\r\n"		//the message
	cmd += "\r\n.\r\n"		//finish the message and send
        sockitsendmsg sock, cmd
	killwaves /z buf
The only trouble is that the server may barf because the whole message arrives at once.
