Print Folders and Files Recursively
//	PrintFoldersAndFiles(pathName, extension, recurse, level)
//	Shows how to recursively find all files in a folder and subfolders.
//	pathName is the name of an Igor symbolic path that you created using NewPath or the Misc->New Path menu item.
//	extension is a file name extension like ".txt" or "????" for all files.
//	recurse is 1 to recurse or 0 to list just the top-level folder.
//	level is the recursion level - pass 0 when calling PrintFoldersAndFiles.
Function PrintFoldersAndFiles(pathName, extension, recurse, level)
	String pathName		// Name of symbolic path in which to look for folders and files.
	String extension			// File name extension (e.g., ".txt") or "????" for all files.
	Variable recurse		// True to recurse (do it for subfolders too).
	Variable level			// Recursion level. Pass 0 for the top level.
	Variable folderIndex, fileIndex
	String prefix
	// Build a prefix (a number of tabs to indicate the folder level by indentation)
	prefix = ""
	folderIndex = 0
	do
		if (folderIndex >= level)
			break
		prefix += "\t"					// Indent one more tab
		folderIndex += 1
	while(1)
	// Print folder
	String path
	PathInfo $pathName				// Sets S_path
	path = S_path
	Printf "%s%s\r", prefix, path
	// Print files
	fileIndex = 0
	do
		String fileName
		fileName = IndexedFile($pathName, fileIndex, extension)
		if (strlen(fileName) == 0)
			break
		Printf "%s\t%s%s\r", prefix, path, fileName
		fileIndex += 1
	while(1)
	if (recurse)									// Do we want to go into subfolder?
		folderIndex = 0
		do
			path = IndexedDir($pathName, folderIndex, 1)
			if (strlen(path) == 0)
				break							// No more folders
			String subFolderPathName = "tempPrintFoldersPath_" + num2istr(level+1)
			// Now we get the path to the new parent folder
			subFolderPath = path
			NewPath/Q/O $subFolderPathName, subFolderPath
			PrintFoldersAndFiles(subFolderPathName, extension, recurse, level+1)
			KillPath/Z $subFolderPathName
			folderIndex += 1
		while(1)
silvan.roth
Hi
I'm trying to use the procedure above to load excel files from different subdirectories from my PC. However, I cannot place a running index somewhere in the code such that it increases by one for each file that's loaded. How can I do that?
Cheers
Silvan
hrodstein
If I understand your question, the only simple way to do this is to create a global variable initialized to 0 in your top-level function and increment it in PrintFoldersAndFiles where the fileIndex variable is incremented.
A cleaner but more complicated solution is to add a pass-by-reference parameter and increment it in PrintFoldersAndFiles where the fileIndex variable is incremented. This is cleaner because it avoids the use of a global variable.
For details on pass-by-reference parameters, execute:
DisplayHelpTopic "Pass-By-Reference"
