This is probably a pretty simple issue, but I've not programmed much in Igor. I need to make a series of waves that have the same name with a nummerical index that increases by 1 with each new wave (wave1, wave2, wave3 etc). I tried the code below, but it won't compile with the "i" following the wavename in the make command. If I leave the "i" out, then it compiles and runs, but I get an error after the first iteration because the name already exists (duh!). I've been reading the Igor manual on Strings all day.... Help!
The error occurs because Igor cannot add a number to a string (name + i) (actually which error gets thrown depends on the precedence of the $ operator, but you can ignore that). Instead you can try the following:
variablei = 0
Do
name = "Diff"+nameofwave(Length) + num2istr(i) make$name i += 1 while(i<=100)
Note that I would typically use a for loop for this.
operator, but you can ignore that). Instead you can try the following:Do
make $name
i += 1
while (i<=100)
for
loop for this.March 14, 2012 at 09:43 am - Permalink
March 14, 2012 at 10:37 am - Permalink
