Igor Pro 10 Released
WaveMetrics is thrilled to introduce Igor Pro 10 – the next‑generation data‑analysis platform for Windows that ships with built‑in Python integration, a modernized procedure window, and powerful new hardware‑control tools. Upgrade today to unlock faster workflows, richer visualizations, and seamless access to the ever‑growing Python ecosystem.
Download Igor Pro 10
Some highlights of Igor Pro 10 include:
  • Built‑in Python: Run Python code directly from Igor, exchange data via the igorpro module, and launch full scripts with the new Python and PythonFile operations.
  • MMI XOP for hardware control: Leverage μManager to drive cameras, stages, shutters, and more, with streamlined commands and HDF5 streaming.
  • Procedure window upgrades: Enhanced syntax highlighting, smarter code completion, clickable function jumps, line‑continuation everywhere, and collapsible code blocks.
  • Multipeak fitting enhancements: More robust error handling, hold‑strings wave, higher‑resolution scaling, and reliable auto‑locate.
  • Advanced drawing tools: Refined polygon/Bezier editing, vertex snapping, contextual menus, and new drawing layers (ProgTop, UserTop).
  • Page‑layout refinements: Margin‑only guides, precise guide dragging feedback, and accelerated keyboard‑based positioning.
  • Control‑panel anchoring: Anchor controls to guides for responsive panel designs without extra scripting.
  • Internationalization: Automatic UI switch to Japanese on matching OS locales, eliminating the need for a separate license.
  • New operations & functions: Interp4D, Say, plus 20 new MatrixOp functions.
  • Performance boosts: Faster compilation, optimized NewPath/IndexedFile operations, and full utilization of all logical processors on Windows 11.
Upgrade now and experience a smoother, more powerful Igor Pro that brings your data science to the next level.
For more information see the comprehensive list of new features.
Igor Pro 10 is a paid upgrade from previous Igor Pro versions. You can purchase an upgrade from the WaveMetrics online store. A trial version is available and can be installed without the need to uninstall previous versions of Igor Pro.
If you purchased an Igor Pro 9 license or upgrade on or after January 1, 2025, you should have already received your Igor Pro 10 activation information from WaveMetrics. If you believe that you are eligible for a free upgrade and have not received your upgrade information, please contact sales@wavemetrics.com. Make sure to provide information we can use to identify your order, such as your Igor Pro serial number or WaveMetrics order number.
IGOR PRO 10 SYSTEM REQUIREMENTS:
Igor Pro 10 is a 64-bit Windows application and requires Windows 10 or later. It does not run on macOS except under Windows virtual environments.
See the announcement of discontinuing Igor development for macOS here.
Igor Pro 10 on Windows 10 and Later
Igor Pro 10 is based on the Qt 6 cross-platform application framework, which handles high resolution screen scaling differently (better) than Qt 5 did.
Unlike Igor Pro 7-9, Igor Pro 10 is 64-bit only. This means that any XOPs you use with Igor Pro 10 must also be 64-bit.
Igor Pro 10 is a native x64 application and WaveMetrics only supports running Igor Pro 10 on machines with Intel/AMD CPUs.
However, the Igor Pro 10 installer should also allow Igor to be installed on Windows ARM64 machines (both virtual and non-virtual). In order to run Igor 10, your machine/OS will need to support x64 emulation (we recommend Windows 11 24H2 or later for best results). Note that WaveMetrics does not explicitly support running Igor Pro 10 under ARM emulation, but we may do so in the future. Please report bugs to us if you are using such a configuration, but realize that our ability to fix them may be limited.
