Igor Pro 10 Readme
Windows System Requirements
Igor Pro® 10 is a native x64 application and WaveMetrics only supports running Igor Pro 10 on machines with Intel/AMD CPUs.
However, the Igor Pro 10 installer should also allow Igor to be installed on Windows ARM64 machines (both virtual and non-virtual). In order to run Igor 10, your machine/OS will need to support x64 emulation (we recommend Windows 11 24H2 or later for best results). Note that WaveMetrics does not explicitly support running Igor Pro 10 under ARM emulation, but we may do so in the future. Please report bugs to us if you are using such a configuration, but realize that our ability to fix them may be limited.
Unlike Igor Pro versions 7-9, which shipped as both 32-bit and 64-bit applications, Igor Pro 10 is 64-bit only. This means that any XOPs you use with Igor Pro 10 must also be 64-bit.
macOS Support Discontinued
Igor Pro 10 does not run on macOS except under Windows virtual environments.
See the announcement of discontinuing Igor development for macOS here.
