Adding value labels for category plots
Hi,   What is the way of adding value labels (blue numbers on the attached figure) to a category plot? The picture is taken from here. Thanks   category plot
The blue labels are added by adding the Y data to the graph a second time, setting the plotting mode to markers, and selecting Text Markers. The wave selected for the text markers is a wave with those numbers (the actual change in population of each county). I then set the mode of the bars to Bars to Next so that the text is in the same category column as the bars.
And to be absolutely honest, since I wanted those blue labels to be all above the zero line, I created a duplicate of the wave and set all the negative values to zero.
That graph, by the way, is in an example experiment file that ships with Igor. Select File->Example Experiments->Sample Graphs->Demo Experiment #2.
