I am trying to write a general function to write to a text a row of comma or tab or colon etc separated variables from a selection of 1d waves of the same length. I have done this for a fixed number of waves with the wave references hard wired into to the code. The fprintf operation has enough flexibility to specify the format needed. But I cannot see a way of doing this with a user specified number of waves. My thoughts have been to build a text wave with the strings containing the names of the waves to be output, and then put it in a loop to set up the wave referencing for each wave. But I can't see how to do using straightforward wave referencing. I have considered perhaps using duplicate or make to set up dummy waves in the function and deleting them at the end but this seems very clunky. I also think I could probably do it in a macro ... any advice welcome
I suspect a loop will be needed at some point. Perhaps you are writing the values of the waves as a CSV row, one row per wave. Iterative over the wave names. Write each wave to a string and concatenate the strings. Alternatively, perhaps you are writing the values of the waves as a CSV column, one column per wave. I'd consider putting the waves in to a (FREE) matrix wave, transpose the matrix, and use the method described above to write contiguous rows.
If you've figured out a way to do it with fprintf and the wave names hardwired, then the trick may just be to use the Execute operation. You'd create a string that contains the full fprintf command, including the user-specified waves, then Execute that string. You might run into string length limits.
Function PrintRow(ww,row)
Wave/WAVE ww
Variable row
Variable numWaves = numpnts(ww)
String text = ""
Variable i
for(i=0; i<numWaves; i+=1)
String temp
Wave w = ww[i]
Variable value = w[row]
sprintf temp, "%g", value
text += temp
if (i < (numWaves-1))
text += ","
Printf "%s\r", text
Function Demo()
Make/O/N=5 wave0=p, wave1=p+1, wave2=p+2
Make/FREE/WAVE/N=3 ww
ww[0] = wave0
ww[1] = wave1
ww[2] = wave2
PrintRow(ww,1)
Thanks for all the suggestions and comments that have led to me successfully writing a very flexible function that does all the things I wanted of it! I built the text wave with names of waves I wanted to output and applied these in a loop to fill a multidimensional wave containing each of the waves for output as columns. I then loop the multidimensional wave a row at a time with sprintl formatting of each data item including the file separators, concatenate these together and output with a fprintf.
October 26, 2017 at 11:03 am - Permalink
October 26, 2017 at 01:38 pm - Permalink
October 26, 2017 at 02:16 pm - Permalink
October 28, 2017 at 07:14 am - Permalink
