Help taking an integral within a Function I want to plot
Hi, I am trying to plot the attached equation.  I want to make a plot with E_A on the y-axis and G on the x-axis.  However, I am struggling to determine the best method for coding the integral over x.  Every other variable is a constant.  Do I need to do this as a 2-D wave?  Thanks
Screen Shot 2019-05-29 at 3.37.09 PM.png (24.55 KB)
jjweimer
My suggestion ...
First, code the function inside the integral. Code it to return to a wave dEAx<-Function fdEAx(G,lambda,T,x). Set the scale on dEAx to large values of -start to +end.
Plot dEAx as a function of x for a fixed value of G (lambda, T). Code a function that will integrate dEAx. Report the last point of that function.
Now, run the sequence
* generate a dEAx(G) curve
* integrate it
* capture the end point of the integration to a new wave iEA(G) for the given G value
Continue above for a range of G of interest.
Igor
My approach is dated; I recommend using pen and paper to rewrite the integral.  Start by re-writing the exponential in the numerator as a couple of factors (one of which can come out of the integral).  Then make a change of variable say f=x/RT.  You should now have a simple integrand that you can evaluate at three critical points: x=-INF,0,INF.  The result of this will indicate how to proceed.
