How can we concatenate a string with a variable number included?
I would like to change the name of a wave in a for loop. For example, something which could give me d0 at the first iteration, d1 at the second one, up to dimax where imax is the maximum number reached by the loop variable i.
I tried something like name="d"+i, where name is a string.
but it doesn't work, cause apparently it is impossible to concatenate a string with a variable number. So I have to use a switch command on i, and do it imax times in my for loop, which is very painfull...
Please, would you help me to find the way to do what I am trying to? That would really simplify my life a lot....
Thanks in advance
Barbara
741
Igor considers variables and strings to be entirely different things that don't mix with one another. If Igor expects a string for something, you cannot provide it with a variable, and vice versa.
To bridge the gap between them you need to use special conversion functions:
variable i
string badName = "d" + i // error: mixing string and variables
string goodName = "d" + num2str(i) // good: num2str copies the number in the variable into a string
In that case you will need to look into the
operator. Execute
. This can be confusing. However, consider this:
  • Imagine that "someStr" is a string.
  • If you type
    wave hello = someStr
    , Igor will look for a wave with the literal name "someStr". It will not look at the contents of the string variable.
  • But if you type
    wave hello = $someStr
    , then the
    tells Igor to look at the contents of the string to get to the name of the wave you're interested in.
  • Barbara
    Thank you so much, it is exactly what I needed! I had a look in the help files but I didn't find that.
    johnweeks
    Barbara wrote: I had a look in the help files but I didn't find that.
    It can be hard to find if you don't know what you're looking for. You can read about this topic by executing this command on Igor's command line:
    Starting at that topic, there is quite a lot of relevant material in the following sections.
    Another useful topic:
