LoadData from a series of experiments
I am using loaddata to import waves from one pack experiment to the other.
I use it 2 ways:
LoadData/O/L=1 path+file // when I want all the waves that were in the experiment
LoadData/O/J=objectlist path+file // when I want some waves whose name was defined
Now I would like to load the waves that for example only start with "TOP". So What I have down is that I use LoadData/O/L=1 path+file and then I kill all the waves that do not start with "TOP". The problem is that loading all the experiment for each file is long and I get pretty quickly out of memory.
*So maybe you could tell me if there is a way to load the list of wave in the experiment, simply a string that would contain the wave names as datafolderdir(2) but for the second experiment.
Then I could select the waves using this string and load only the one I need.
If you have any other suggestion I am more than happy to hear them!
Thank you in advance,
Celine
Igor's memory management was improved in Igor Pro 6.00. If you are using an earlier version, upgrade to Igor Pro 6.1 and that should solve the memory problem.
You can download the Igor Pro 6.1 demo from the WaveMetrics web site. It is fully function for 30 days.
July 29, 2010 at 10:14 am - Permalink
August 2, 2010 at 11:16 am - Permalink
-Matthew
January 11, 2018 at 01:08 pm - Permalink
command.
'Tempstring' contains a pattern of skipped (e.g., "C=1,N='_skip_'; ") and parsed (e.g., "C=1,F=0,T=2,N=Frequency; ") parameters for each column.
However, this was on IP6.3x. (If you still use IP6.1, you might want to update...)
HJ
EDIT: I Just realized that the question was on LoadData and not on LoadWave.
Maybe programming the data browser might help?
January 11, 2018 at 03:30 pm - Permalink
Yes for Igor7.
I am investigating the feasibility of providing more flexibility for Igor8. I should know more in a day or two.
January 11, 2018 at 06:11 pm - Permalink
If you are interested in testing this feature, you first need to become an Igor8 beta tester - see https://www.igorpro.net/beta-signup. You will need a valid activation key for an Igor Pro 7 license with to become a beta tester.
Once you have signed up and installed the Igor8 beta, choose Help->Igor Pro Nightly Builds and install the latest nightly build.
Finally, to get documentation for the new LoadData feature, in Igor8 choose Help->Contact Support to create a new email addressed to WaveMetrics support. Enter "LoadData with Regular Expressions" for the subject, enter a brief explanation of what you are trying to do in the body, and send the request to support.
January 17, 2018 at 10:03 am - Permalink
I figured out a workaround. I made people name their waves intelligently (i.e. with a sequential index, i.e. wave0, wave1, wave2, ...), so I could stop loading when LoadData failed to find the file.
That solution may only work for my particular situation, of course.
-mxf
January 19, 2018 at 06:40 am - Permalink
