Creating image plot with multiple scalings
Epitrochoid
Thu, 05/28/2020 - 12:01 pm
Hi all,
I want to create a image plot with 20 waves. Each wave has 5000 points but different scaling. For example the first wave has a scaling with a delta of 0.006 and the last wave has a scaling with a delta of 0.002.
Can someone help me?
Set the x and y scaling for each of your waves. Then display one of the waves and append the others using the builtin calculated values for x and y you set from scaling. Important to note: That if the image X and Y ranges overlap then you will see only top image.
May 28, 2020 at 12:05 pm - Permalink
Thanks for the help.
Can you explain how i can change the X and Y ranges or where i can find a solution for this problem?
May 28, 2020 at 01:00 pm - Permalink
In Menu
Data>Change Wave Scaling...
You can set the X and Y scaling (ranges of your wave). The top pop let's you select X or Y. You can also choose by point or range.
I would suggest you spend a bit of time understanding wave scaling. This is a very important underlying feature of IP and extremely powerful. Basically you embed the ranges into your wave for example your image that 640 x 480 pixels. I can set the X scale to go from 0 to 13.2 and the Y go from 2 to 47. I can then use the calculated X & Y values
May 28, 2020 at 01:22 pm - Permalink
Are you saying that you have 20 1D waves, and you want to combine them into a single image? Or do you have 20 2D waves and you want 20 images?
May 28, 2020 at 01:57 pm - Permalink
