Autoscaling graphs - hidden traces with error bars
Could not find a similar issue, so I will query here as to whether this is a bug, or whether I am misunderstanding how hidden traces work.
When hiding a trace on a normal graph, there is the option to either have the axes autoscale to just the visible traces with
modifygraph hidetrace(waveRef) = 1
or alternately to autoscale the axes even including the hidden trace, ie
modifygraph hidetrace(waveRef)=2
However, this doesn't work if the waveRef in question has error bars included. If the hidden trace has an errorbar added, ie
errorbars waveRef y,pct=2
\\\OR
errorbars waveRef y, wave=(errorwave1,errorwave2)
then the behaviour of the plot is as if the trace was included in the autoscale (ie hidetrace=2, even if 1 is specified).
Is this the desired behaviour of the hidetrace option?
Cheers,
-jld
johnweeks
And now, finally, after over 3 days of power loss, I have managed to fix this bug. The next nightly build of both Igor 8 and 9 will have the fix.
