constant namespace (module?)
Is there a way to limit the namespaces for constants similar to modules
do for Functions?
The following doesn't work:
-- Procedure "testc.ipf"
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3
#pragma moduleName=xxx
Static Constant ktest = 42
-- Procedure
#pragma rtGlobals=3
Function doit()
        Variable x
        x = xxx#ktest
        print "x is", x
The callers of my functions needs access to several constants
(the same and/or different constants for each function).
These functions include both Igor procedures/functions and XOP/functions.
I'm worried about namespace collisions on the constant names.
PS: What about Structures too?  This seems less of a problem to me since
    I can use a very long name for the structure as the structure name
    will appear less often (and the STRUCT variable is local).
You can make constants static (local to a file).
Accessing the constant from outside that file using moduleName#constantName isn't supported (yet), but you can use a static function that returns the constant and call that static function using the module name.
#pragma rtGlobals=3
Static Function Get_ktest()
        return ktest
-- Procedure
#pragma rtGlobals=3
Function doit()
        Variable x
        x = xxx#Get_ktest()
        print "x is", x
Is there a timeline for being able to access static constants from another proc file using the moduleName#constantName syntax?
