Baseline fit and subtract of an image
Is there any way to fit and subtract the baseline of an image?
I wrote this function to load the .hdf5 file and plot this image.
Function LoadReflectanceImageFile([variable x_min, variable x_max, variable y_min, variable y_max, variable x_length, variable y_length, string file_name])
	x_min = paramIsDefault(x_min) ? -1 : x_min //this means x_min = -1
	x_max = paramIsDefault(x_max) ? 1 : x_max //this means x_max = 1
	y_min = paramIsDefault(y_min) ? -1 : y_min //this means y_min = -1
	y_max = paramIsDefault(y_max) ? 1 : y_max //this means y_max = 1
	x_length = paramIsDefault(x_length) ? 201 : x_length //this means x_length = 201
	y_length= paramIsDefault(y_length) ? 201 : y_length //this means y_length = 201
	String datasetName="DAC-ADC - BUFFER_RAMP"
	Variable groupID
	Variable fileID
	variable i,j
	HDF5OpenFile /R /Z fileID as ""	// Displays a dialog
	if (V_Flag != 0)
		return -1       // User cancelled
	if (V_flag == 0)	// User selected a file?
		make/o/n=(x_length,1,0,y_length) tempReflectanceImageData
		HDF5OpenGroup /Z fileID, "./Traces", groupID
		HDF5LoadData /N=tempReflectanceImageData /O groupID, datasetName
		HDF5CloseFile fileID
	if(!ParamIsDefault(file_name))
		make/o/n=(x_length,y_length) $file_name
		Wave newWave = $file_name
		for(i = 0; i < x_length; i++)
			for(j = 0; j< y_length; j++)
				newWave[i][j] = tempReflectanceImageData[i][0][j]
		showImages(newWave, xLabel="x-axis", yLabel="y-axis", colorLabel="Reflectance")
		SetScale/I x x_min,x_max,"", newWave
		SetScale/I y y_min,y_max,"", newWave
		make/o/n=(x_length,y_length) ReflectanceImageData
				ReflectanceImageData[i][j] = tempReflectanceImageData[i][0][j]
		showImages(ReflectanceImageData, xLabel="x-axis", yLabel="y-axis", colorLabel="Reflectance")
		SetScale/I x x_min,x_max,"", ReflectanceImageData
		SetScale/I y y_min,y_max,"", ReflectanceImageData
	killwaves tempReflectanceImageData
	Label bottom "\\f01\\Z30\\F'Times New Roman' x-axis [V]"
	Label left "\\f01\\Z30\\F'Times New Roman' y-axis [V]"
	ColorScale/C/N=text0 "\\f01\\Z30\\F'Times New Roman' Reflectance [mV]"
	return 0            // Success
I have also attached the .pxp & .hdf5 and file.
​​​​​Any help and suggestions are appreciated.
- Doha
Reflectance Scan Image Archive.zip (554.26 KB)
Igor
Hello Doha,
I suggest you start by executing the following command:
DisplayHelpTopic "Background Removal"
This will take you to a relevant discussion in the ImageProcessing Tutorial that illustrates an approach for solving this problem.
In reply to by tony
doha420du
When I plot one column of this matrix, I got the attached plot. I tried and @Tony's Baseline code works perfectly.
so, I was thinking of doing that for all columns and automatically. I think a more appropriate word will be 'background correction'. Sorry about that.
chozo
So you mean the rather broad signal variance underlying your signal, which I would describe maybe as 'inconsistent illumination'. At first I thought that you could just take an average of the profile at the lower edge of your image data and subtract or otherwise normalize the whole image with it (see attached subtracted image 'subtracted profile - edge'). But it seems the 'baseline' differs in size in different parts of the image, i.e., the slope is smaller in the center than on the edges. This makes things quite difficult, I guess. Also, your image is slightly rotated, which would make it very difficult to find a reasonable baseline for the upper and lower edges of your structure.
It seems the baseline shape can be reasonably described by a Gaussian. I would try to fit a Gaussian (with width and position fixed, i.e., only height variable) to the data on the left and right outer rims of your image (where there is no structure) and try to construct a reasonable baseline based on the varying overall intensity. You need to decide what to do at the upper and lower edges. Maybe a smooth transition from the size at the rim and the center could do. If you do not care about the outer parts, just fixing the center might be enough. I have fitted the baseline of the very center of the image and subtracted it from the whole data (see graph ' subtracted profile - center')
Another approach could be to just save the image and use your favorite image modification software to fix the rotation and make the illumination uniform, e.g., with a gradient layer mask.
tony
Maybe this is what you seek to do:
select some region of interest within the image to define as a background region, i.e. the blue areas
fit those values with a 2D function (a surface)
subtract that fit from every pixel value
Is that correct?
