Determine the version of a procedure file
![](/profiles/wavemetrics/themes/wavemetrics/images/icons/employee-icon.png)
aclight
// Determine the version of a compiled procedure window
// named procedureWinTitleStr.
// The version is defined using the #pragma version
// compiler directive. For example,
// #pragma version=1.05.
// As stated in the Igor documentation, the line must
// start flush with the left of the window (that is, there
// can be no leading whitespace). Spaces
// and tabs within the directive are ignored.
// Returns NaN if procedure window doesn't exist,
// 1.00 if no version is defined in the procedure window,
// or the version that is defined in the procedure window.
Function GetProcedureVersion(procedureWinTitleStr)
String procedureWinTitleStr
// By default, all procedures are version 1.00 unless
// otherwise specified.
Variable version = 1.00
Variable versionIfError = NaN
String procText = ProcedureText("", 0, procedureWinTitleStr)
if (strlen(procText) <= 0)
return versionIfError // Procedure window doesn't exist.
String regExp = "(?i)(?:^#pragma|\\r#pragma)(?:[ \\t]+)version(?:[\ \t]*)=(?:[\ \t]*)([\\d.]*)"
String versionFoundStr
SplitString/E=regExp procText, versionFoundStr
if (V_flag == 1)
version = str2num(versionFoundStr)
return version
if (V_flag == 1)
return version
April 13, 2010 at 10:15 am - Permalink
April 13, 2010 at 02:45 pm - Permalink
Having a return of 0.00 (since NaN is used as a No Procedure File Error flag) still seems a better "no pragma defined" return value than 1.00. While Igor allows procedure files of version = 0.00, I suspect the number of users who purposely code a procedure file with such a version number is far, far smaller than the number who actually use no version pragma in their procedure file.
This is BTW a good standard piece of code to have around to help oversee code development.
April 13, 2010 at 05:13 pm - Permalink
Motivated by Jan's recent post (https://www.wavemetrics.com/forum/igor-pro-wish-list/warn-if-multiple-s…), I'm wondering if the method shown here is still the best way to get a procedure file version from the version pragma?
December 7, 2021 at 07:16 am - Permalink
aclight's snippet gives the version of a currently loaded procedure.
This gives the version from a file:
function getProcVersion(string filePath)
variable procVersion
Grep /Q/E="(?i)^#pragma[\s]*version[\s]*=" /LIST/Z filePath
s_value = LowerStr(TrimString(s_value, 1))
sscanf s_value, "#pragma version = %f", procVersion
if (V_flag!=1 || procVersion<=0)
return procVersion
December 7, 2021 at 08:31 am - Permalink
