Determine the version of a procedure file
// Determine the version of a compiled procedure window
// named procedureWinTitleStr.
// The version is defined using the #pragma version
// compiler directive.  For example,
// #pragma version=1.05.
// As stated in the Igor documentation, the line must
// start flush with the left of the window (that is, there
// can be no leading whitespace).  Spaces
// and tabs within the directive are ignored.
// Returns NaN if procedure window doesn't exist,
// 1.00 if no version is defined in the procedure window,
// or the version that is defined in the procedure window.
Function GetProcedureVersion(procedureWinTitleStr)
	String procedureWinTitleStr
	// By default, all procedures are version 1.00 unless
	// otherwise specified.
	Variable version = 1.00
	Variable versionIfError = NaN
	String procText = ProcedureText("", 0, procedureWinTitleStr)
	if (strlen(procText) <= 0)
		return versionIfError		// Procedure window doesn't exist.
	String regExp = "(?i)(?:^#pragma|\\r#pragma)(?:[ \\t]+)version(?:[\ \t]*)=(?:[\ \t]*)([\\d.]*)"
	String versionFoundStr
	SplitString/E=regExp procText, versionFoundStr
	if (V_flag == 1)
		version = str2num(versionFoundStr)
	return version
jjweimer
Perhaps a better return for a procedure file with no #pragma version information should be 0.00 instead of 1.00. That would allow also for distinguishing from procedure files that are version 1.00.
aclight
I thought about that, but Igor allows you to declare the version of your procedure as 0 or even a negative number, if you wish. I assume that it also allows you to declare the version to be NaN, but that is less likely to be an issue, I suspect.
jjweimer
Oh! Odd but understandable.
Having a return of 0.00 (since NaN is used as a No Procedure File Error flag) still seems a better "no pragma defined" return value than 1.00. While Igor allows procedure files of version = 0.00, I suspect the number of users who purposely code a procedure file with such a version number is far, far smaller than the number who actually use no version pragma in their procedure file.
This is BTW a good standard piece of code to have around to help oversee code development.
tony
aclight's snippet gives the version of a currently loaded procedure.
This gives the version from a file:
// extract procedure version from file
function getProcVersion(string filePath)
	variable procVersion
	Grep /Q/E="(?i)^#pragma[\s]*version[\s]*=" /LIST/Z filePath
	s_value = LowerStr(TrimString(s_value, 1))
	sscanf s_value, "#pragma version = %f", procVersion
	if (V_flag!=1 || procVersion<=0)
	return procVersion
