Function trigger for trace offset?
tkessler
Sat, 01/05/2013 - 06:11 pm
Does anyone know a hook or other method to use for triggering a function upon offsetting a trace? I'd like to be able to drag a trace in a graph window to a new location (ie, for offsetting a threshold trace), and then when released have igor execute a function to take into account the new offset location, etc.
Any ideas?
Caveat: The hook is not called if the trace offsets are set by a command, only if set by dragging.
String graphNameStr
Variable traceIndex // 0 for first trace, 1 for second, . . .
Variable& xOffset // Output
Variable& yOffset // Output
xOffset = NaN
yOffset = NaN
String info = TraceInfo(graphNameStr, "", traceIndex)
if (strlen(info) == 0)
return -1
// Strip out everything before "offset(x)" - (would not be necessary if I knew what I was doing with regular expressions)
Variable pos = strsearch(info, "offset(x)", 0)
Variable len = strlen(info)
info = info[pos,len]
// Strip out everything after next semicolon - (would not be necessary if I knew what I was doing with regular expressions)
pos = strsearch(info, ";", 0)
info = info[0, pos]
// Extract x and y offsets as strings
String regExp = ".*offset\\(x\\)={([^,]*),([^\\}]*)"
String xOffsetStr, yOffsetStr
SplitString /E=regExp info, xOffsetStr, yOffsetStr
// Convert to numbers and return via pass-by-reference parameters
xOffset = str2num(xOffsetStr)
yOffset = str2num(yOffsetStr)
Function MyWinHook(s)
STRUCT WMWinHookStruct &s
Variable xOffset, yOffset
Variable rval= 0
switch(s.eventCode)
case 4: // Mouse down
GetTraceOffset(s.winName, 0, xOffset, yOffset) // 0 means first trace
// Printf "xOffset=%g, yOffset=%g\r", xOffset, yOffset
Variable /G root:gLastXOffset = xOffset
Variable /G root:gLastYOffset = yOffset
break
case 5: // Mouse up
NVAR lastXOffset = root:gLastXOffset
if (xOffset != lastXOffset)
Printf "New X offset = %d\r", xOffset
NVAR lastYOffset = root:gLastYOffset
if (yOffset != lastYOffset)
Printf "New Y offset = %d\r", yOffset
break
endswitch
return rval
Function DemoSetCursorHook()
Make/O jack=x
Display jack
SetWindow kwTopWin,hook(testhook)= MyWinHook
For details on window hooks:
Another approach would be to use a background task to look at the trace offsets periodically.
January 5, 2013 at 09:42 pm - Permalink
eventCode=8
eventName="modified"
A modification to the window has been made. This is sent to graph and notebook windows only. It is an error to try to kill a notebook window from the window hook during the modified event.
NOTE: If your function modifies the graph, add recursion protection to prevent responding to the resulting "modified" event again.
January 6, 2013 at 10:16 am - Permalink
January 6, 2013 at 05:42 pm - Permalink
