How to delete a merged experiment folder
ali8
Sat, 01/24/2015 - 01:19 pm
I merged several experiments into my main experiment. Now when I try to plot a new graph or table, they appear within a 'folder' icon, within which are all the waves imported from that experiment. That's fine. But how can I delete such folder if I no longer want it? I deleted (killed) all the waves within, but the folder is still there. The problem is that I have a lot of folders that hinder quick wave selection.
January 24, 2015 at 02:50 pm - Permalink
There should be a Data Browser item at the bottom of the Data menu. If you don't see it then your installation is probably messed up. You should reinstall Igor.
To learn about data folders, execute:
DisplayHelpTopic "Data Folders"
January 24, 2015 at 05:30 pm - Permalink
I think you want the KillDataFolder operation.
From the command help:
January 25, 2015 at 12:52 pm - Permalink
(To be clear, there is a "browse wave" option, but I think that's something different)
January 25, 2015 at 01:03 pm - Permalink
The Data Browser is created by a file named "Data Browser.xop" in "C:\Program Files (x86)\WaveMetrics\Igor Pro Folder\Igor Extensions". Igor finds "Data Browser.xop" by looking for it in the "Igor Extensions" folder which is located relative to the location of the Igor.exe file.
It is sounding like you have dragged the Igor.exe icon out of the Igor Pro Folder onto the desktop instead of dragging a shortcut onto the desktop.
Find the Igor Pro Folder (usually in "C:\Program Files (x86)\WaveMetrics\Igor Pro Folder" or something similar) and open it in Windows Explorer. Now double-click the Igor.exe file in Igor Pro Folder to launch Igor. You should have a Data Browser item at the bottom of the Data menu.
January 25, 2015 at 02:13 pm - Permalink
I don't know why is that the case, but anyway I solved my problem, although I'd like to know if there is any trick to do so that all instances have the Data Browser. Otherwise, that's fine.
January 26, 2015 at 06:13 am - Permalink
Pressing shift has always disabled extensions, a.k.a., XOPs. Since the Data Browser is an XOP, pressing Shift disables it.
January 26, 2015 at 10:23 am - Permalink
January 26, 2015 at 10:26 am - Permalink
