how to kill table/graph macro that is useless?
under the menu "windows->table macros" and "windows->graph macros", I found several table or graph were created by mistake and want to kill them. But I don't not find out the way.
anyone can tell me the tip. thanks.
KurtB
The macros for tables and graphs are in the main procedure window. Choose "Windows->Procedure Windows->Procedure Window" (or ctrl+M on a PC). Then look for a Window macro corresponding to the unwanted table or graph and delete it.
pangeng
KurtB wrote: The macros for tables and graphs are in the main procedure window. Choose "Windows->Procedure Windows->Procedure Window" (or ctrl+M on a PC). Then look for a Window macro corresponding to the unwanted table or graph and delete it.
thank you. but I don't know how to delete the table in the procedure window. am I supposed to use any command?
hegedus
The procedure window are the macros for generating the tables and graphs. It is also where you program your custom functions. It is just a text window similar to notepad. Just highlight the text you want removed and hit delete or backspace key.
for example if I had a useless table such as
Window Table0() : Table
PauseUpdate; Silent 1 // building window...
Edit/W=(5,45,510,252) textWave0
ModifyTable format(Point)=1
EndMacro
I would highlight from Window through EndMacro and hit delete.
