Killing Graphs From Command Line
I have searched the Web, the Help files, and everywhere in between. I cannot find a way to kill graphs from the command line. It's easy to kill waves, but what about graphs, or even tables? Is there a way to kill these objects from the command line?
jjweimer
patarroyo wrote: I have searched the Web, the Help files, and everywhere in between. I cannot find a way to kill graphs from the command line. It's easy to kill waves, but what about graphs, or even tables? Is there a way to kill these objects from the command line?
Look under DoWindow/K or KillWindow.
patarroyo
Dr. Weimer, thanks a lot, you are always a huge help. Sorry I couldn't figure this out on my own, but the manual is just so thick...
Here is the preliminary solution I came up with. Basically, this macro relies on the default graph name being "Graph#". It will give an error if "endnum" exceeds the actual number of graphs, or if there is a non-sequential ordering of the graphs (e.g. graphs 1-3 exist, and 5-7, but not graph4. The function will fail on graph4). I am all ears if someone would like to point out some good ways to avoid error codes, but for now, this helps me quite a bit. I often times generate 10-20 graphs just to look at them once, and then kill them, no need to bring them up later.
#pragma rtGlobals=1
Function KillGraphs(startnum, endnum)
	Variable startnum, endnum
	Variable i
	String WindowName
	for(i=startnum; i<=(endnum); i+=1)
		WindowName="Graph"+num2str(i)
		KillWindow $WindowName
-Mike
jjweimer
patarroyo wrote: ... point out ways to avoid error codes ...
Try the following:
	Variable i
        String WindowName
                if (WinType($WindowName) == 1)
aclight
Jeff's code has a typo in it. What you really want is this:
	Variable i
        String WindowName
                if (WinType(WindowName) == 1)
I removed the $ before WindowName in the call to WinType().
bech
Here's yet another possibility. It kills all graphs and windows.
function kill_graphs_and_tables()
	string object_name
	variable string_length
	do
		object_name = WinName(0,3)			// name of top graph or table  (see III-441)
		string_length = strlen(object_name)	        // returns "" if no graph/table is present
		if (string_length == 0)
			break
		DoWindow /K $object_name			// kill top graph or table; keep going till all done
	while (1)                                                            // loop forever until break
John Bechhoefer
Department of Physics
Simon Fraser University
Burnaby, BC, Canada
patg
Or this, to kill any of graphs, tables, layouts, notebooks, panels, XOP windows:
// KillOrHideAnyWindow
//   'KillOrHideAnyWindow' kills any graph, table, layout, notebook, panel, or XOP window
//   PARAMETERS:
//        - winMask:      bitmask of window types to kill
//                          - 0x0  kill everything possible
//                          - 0x01 graphs
//                          - 0x02 tables
//                          - 0x04 layouts
//                          - 0x10 notebooks
//                          - 0x40 panels
//                          - 0x1000 XOP target windows
FUNCTION KillOrHideAnyWindow(winMask)
	variable                      winMask;
	variable                      i,n;
	variable                      all=0x1000+0x40+0x10+0x4+0x2+0x1;
	string                        theWins;
	winMask = !winMask ? all : winMask;
	theWins = winList("*",";","WIN:"+num2iStr(winMask & all));
	for(i=0,n=itemsInList(theWins,";") ; i<n ; i+=1)
		doWindow/K $stringFromList(i,theWins,";");
	endfor;
END
Regards,
Patrick.
Bplus
Q: Kill most RECENTLY opened window?
Is there a simple way to kill the most recently opened window without knowing it's name?
Thanks
hrodstein
No, but you can kill the top graph:
Function KillTopVisibleGraph()
	String topGraph = WinName(0, 1, 1)
	if (strlen(topGraph) == 0)
	DoWindow /K $topGraph
	return 1
If you really want to kill the most-recently-created graph, you would have to keep track of the time of creation. This could be stored as user data in the graph but it is much more complicated than killing the top graph.
