Programmatically opening procedure windows
Is there a way to programmatically open a procedure window? I basically want to enact the menu item 'Go to myFunction' that you can use by right clicking on a function call within a procedure window or in the command line.
The context is a panel that has a drop down menu with different user defined functions. I'd like to have a button next to it that can pull up the .ipf of the selected function, so the user can easily navigate to that function's code.
Thanks for any help.
Found DisplayProcedure function just after posting. Good to go!
October 7, 2019 at 03:02 pm - Permalink
