Q: How to force quit a running procedure?
Is there a short-cut key to force quit a running procedure?
thanks,
YHL
On a PC, it's Ctrl+Break, or click the Abort button at the bottom of Igor's window frame.
On a Mac, it's command-period (the period key with command held down).
I've just come across this issue on a Mac (there is no abort button to click on). I'll use CMD+. instead - glad to have found this info as it was driving me mad! Is there a reason why there is no abort button on the Mac implementation of Igor?
Another useful alternative is the Function PressEscapeToAbort(phase, title, message) function provided in section IV-6 of the Igor User Manual. This allows for the opportunity of a "softer" function-controlled Abort than what you get by using the key or shortcut.
On Macintosh, Igor doesn't have an outer frame in which it could put such a button like it does on Windows.
Ah yes, of course! I really wish it did. Igor is at least 25% nicer to use on Windows.
... Igor is at least 25% nicer to use on Windows.
That's odd. I find just the opposite to be true. :-)
Maybe I'll start a thread about likes and disklikes on the two platforms. Hopefully I'll learn some new tips on how to ease the pain of Igor on OSX ;)
For an extensive list of tips, choose Help->Shortcuts.
