Using Igor's sum() Command with Nested Math?
astrostu
Wed, 03/02/2016 - 01:16 pm
For example, in Python I can create a list [0, 1, 2, 3, 4] and b list [1, 2]. I can then say: c[0] = numpy.sum(exp(a[:]*b[0])) (I'm new at Python, so forgive some of the old-school explicit indexing.)
I wanted to do the same thing with Igor's
sum
command, but I get errors that it JUST wants a wave, such as c = sum(a)
, but I canNOT do something as simple as c = sum(a*2.0)
.I'm sure I'm missing something obvious? The reason for this is it would remove one of my loops and hopefully speed things up (sped things up in my Python code by ~3x for my test dataset).
You might be able to do what you want with a wave assignment, possibly using intermediate waves. Or perhaps MatrixOP can let you nest some of your computation. MatrixOP is designed for speed.
But no sum command like the one you want.
March 2, 2016 at 02:16 pm - Permalink
March 2, 2016 at 02:46 pm - Permalink
I don't think it adds much overhead. You can test it with this (edited to use Duplicate instead of Make):
// Make/O/N=1E6 testWave = p; Demo(testWave)
Function Demo(w)
Wave w
Variable timerRefNum = StartMSTimer
Duplicate/FREE w, temp // Igor automatically kills free waves
temp = 2 * w
Variable result = sum(temp)
Variable elapsed = StopMSTimer(timerRefNum) / 1E6
Printf "Elapsed time: %g seconds\r", elapsed
return result
March 2, 2016 at 03:00 pm - Permalink
For a compound expression or to speed up execution you should look into MatrixOP.
March 2, 2016 at 04:46 pm - Permalink
No loop needed as far as I can tell. AG says MatrixOP for complex equations. Here's the simple example using implicit looping without MatrixOP.
make/N=2 blist={1,2}, clist
make/N=5/FREE tmp
tmp = exp(alist*blist[0])
clist[0] = sum(tmp)
A clever version might be able to do something with the second dimension in a matrix ...
tmp = exp(alist*blist[q])
clist = sum(tmp[p][])
(though I would not swear by it)
March 2, 2016 at 08:32 pm - Permalink
When I run it once. Because this has to be bootstrapped to understand confidence intervals, running it 1000x under the old method (threaded on an 8-core machine) took 53.3 seconds, under the new method took 20.4 seconds (38% time).
Not bad.
Using a dataset 17.7x larger, old method took 16.1 seconds (39.0x longer than other dataset) to run for the main analysis, and 2223 seconds to bootstrap 1000x. New method took 6.31 seconds (39% time as old method, 44.8x longer than other dataset) and 1110 seconds to bootstrap 1000x (50.0% time as old method, 54.4x longer than other dataset).
March 3, 2016 at 01:48 pm - Permalink
Looks like MatrixOP is the way to go for this, at the moment.
March 3, 2016 at 02:06 pm - Permalink
matrixOP/O outw = rec(junk+1)
MatrixOP/O outw=powr(junk+1, -1)
rec() is MatrixOP's reciprocal function. Both of those lines produce what I think is the expected result.
March 3, 2016 at 02:33 pm - Permalink
Cool! That sped things up another ~40-50%! So to run my code start to finish, on 6k points before today, 62 seconds, now 15 seconds (4.1x faster). On 12k points, 201 -> 43 seconds (4.7x faster). On 78k points, 1527 -> 555 (2.8x). On 107k points before today, 2239 seconds, now 821 (2.7x faster). So, it's not linear scaling, which my other version would do with speed, but it's a matrix operation so I wouldn't expect that, and it's still faster.
March 3, 2016 at 04:00 pm - Permalink
