Zero raised by zero
0^0
yields 1.
0^0
should be equal to
cmplx(0,0)
because 0 = 0 + i*0, where
i = cmplx(0,1)
. But
print cmplx(0,0)^0
yields
(Nan,Nan)
. I think, that is wrong. Is there any setting or pragma, that helps to get the correct result
cmplx(0,0)^0
= (0 + i*0)^0 = 1?
Best regards,
Joerg
thomas_braun
@HJDrescher: If you look into IEEE754-2008 they say on page 44 (9.2.1.)
pown (x, 0) is 1 for any x (even a zero, quiet NaN, or infinity)
where pown(x,y) is x^y for y being an integral number. So this does look correct in Igor.
@joerg.kunze: This does look like a bug indeed. I would contact WM support.
Igor
Hello Joerg,
The value of 0^0 is typically argued based on a limit and required continuity. The same argument does not apply in the complex case where the limit depends on the path (and branch) so returning a NaN is, IMO prudent.
