Resources for a Beginner
I'm relatively new to programming and I was wondering if anyone had suggestions on whether I should learn to program in Igor (the program I will be using for data analysis) or if I should take the time to learn another language first. If the latter, is there a particular language someone would suggest or resources to begin?
Thank you so much!
C
I think it's easier to learn something when I have an actual goal in mind (other than just learning). Since you plan to use Igor for your data analysis, you have a goal and a reason to learn Igor. So I would recommend that you learn to program in Igor. The downside here is that as far as I know there aren't tutorials that teach you how to program using Igor. Most of the guides assume that you have some basic familiarity with programming in general. But if you don't know what a variable or function is, and aren't familiar with different flow controls (eg. for loop, do...while, etc.), you may want to find another resource to teach you the very basics of programming and then start using those ideas in Igor programming.
If you need help learning the very basics of programming, I recommend that you take a look at Codecademy (http://www.codecademy.com/tracks/javascript). They provide free online tutorials that teach you JavaScript, but the first several units focus more on learning to program rather than the language itself.
April 15, 2012 at 09:24 am - Permalink
And you'll find that after you've picked up a single language, like Igor's, other languages become much easier. So even if at some point you find yourself no longer using Igor, the skills you learned will still be useful.
April 15, 2012 at 10:53 am - Permalink
Here is the Igor documentation for learning Igor programming.
There is a short section in the Guided Tour:
DisplayHelpTopic "Guided Tour 3 - Histograms and Curve Fitting[Writing a Procedure]"
I recommend reading the following manual chapters in the PDF manual:
IV-1: Working With Commands
IV-2: Programming Overview
IV-3: User-Defined Functions
IV-5: User-Defined Menus
IV-6: Interacting With The User
The basics of those chapters would make a good introduction to Igor programming.
After doing some Igor programming, you should read Chapter IV-3, "User-Defined Functions" again. Some things that did not sink in on the first reading will make more sense after you have done some programming.
Howard Rodstein
WaveMetrics
April 15, 2012 at 11:50 am - Permalink
April 19, 2012 at 08:50 pm - Permalink
There is now a book about programming Igor (Igor Pro 7).
Use the link, or go to Amazon and search for "Programming in Igor Pro".
Hope this is helpful!
May 15, 2018 at 09:16 am - Permalink
May 20, 2018 at 06:02 pm - Permalink
