Is there a way to fix aspect ratio of the Gizmo window of W:H to 1:1?
I am trying to generate some surface plots for publication, and it would be the best if I can make it as 1:1 as possible. When it is not 1:1, there is deformation of the surface plots exported.
I was trying to eyeball it, but then I wonder if there is a way I can make its W:H to be 1:1, like I can in an image.
I found the commend:
ModifyGizmo aspectratio=1
but it wasn't doing what I expected, appreciate if you can help.
Thanks.
Can you post a MWE (minimal working example) so that we have something to play around with?
February 20, 2019 at 10:40 am - Permalink
Sure, attached is an example.
In it, you will find two Gizmos opened, one vertically stretched, the other horizontally stretched.
I am finding a way to make the Gizmo windows themselves to have a 1:1 aspect ratio.
Also I should have mentioned:
I am running Igor Pro 8.0.3.1 on Windows 10, the x64 version.
February 20, 2019 at 11:22 am - Permalink
Hello Sandbo,
Please explain what you mean by 1:1 aspect ratio. In 3D you have 3 dimensions to consider. Your data in this case is a parametric wave which means that you define the range in all three dimension.
I executed the following commands (you can also see these values from Gizmo Menu->Axis Range...):
At this point, an aspect ratio of 1 as implied by the command above would display the z-extent ~10 times larger than y and ~3x the x direction as implied by the data.
February 20, 2019 at 12:01 pm - Permalink
In reply to Hello Sandbo, Please… by Igor
SandboThanks for your reply, my apology if I was confusing.
Here by 1:1 aspect ratio, I am referring to the Gizmo window itself, meaning that I wanted them to be exactly a square. The reason is that the exported graphics (PNG) will be affected by this arbitrary aspect ratio. I could do it roughly, but when I match them to a table (in illustrator), I can see they always have a bit of stretching.
Please refer to the attached image for a more accurate demo. They are not very important to be exactly 1:1, I believe a small distortion is important, but I wondered if there is a command to set them as a square more easily.
February 20, 2019 at 01:20 pm - Permalink
If it is truly the entire window that needs to be square, you can use the MoveWindow command to achieve that.
February 20, 2019 at 01:52 pm - Permalink
In reply to If it is truly the entire… by johnweeks
SandboThanks, it does exactly what I wanted.
February 20, 2019 at 02:10 pm - Permalink
