SQL XOP errors
I am working with IP8 to load some data into an MySQL data base.
Basically I am running through a list of files and doing a data load.
For(index=1;index<maxindex;index+=1) statement = "load data infile '/Volumes/Patents/MySQL/"+StringFromList(index, thefiles)+"' INTO TABLE patents.ipcr FIELDS TERMINATED BY" if(!index) Statement+= "'\t'IGNORE 1 LINES;" else Statement +="'\t';" endif SQLHighLevelOp /CSTR={connectionStr,SQL_DRIVER_COMPLETE} /O /E=1 statement endfor
This is returning an error.
[MySQL][ODBC 8.0(a) Driver][mysqld-8.0.12]Incorrect date value: '0000-00-00' for column 'action_date' at row 1
SQL XOP: SQLExecute failed.
However if I execute this in MySQLworkbench.
LOAD DATA INFILE '/Volumes/Patents/MySQL/xaa.tsv' INTO TABLE patents.ipcr FIELDS TERMINATED BY '\t' IGNORE 1 LINES;
It works as expected as seen by the data table in the image. On the right hand side you see 0000-00-00 entered into the action date column. This is correct a represents a missing value. This is the correct and desired behavior.
Note: If statement on index is to prevent column headings from the data file being entered as data.
Background: MySQL server is on the same computer. And I have loaded many files successfully. I am recreating the patent database to do some analytics.
How do I resolve?
I think I might have found the solution. In MySQLworkbench there was an option set:
set sql_mode='';
I tested this without this setting and it appears to give the same date error code on loading.
February 28, 2019 at 09:44 am - Permalink
