heatmap with text annotations
Hi everyone!
I'm trying to plot a heatmap with text annotations in Igor Pro. Below is a minimal working example (MWE) that demonstrates what I want to achieve.
However, it seems that the 2D wave gets transposed during imaging (`AppendImage`), which makes it confusing to correctly place text annotations and set tick labels. I have to treat rows as columns (and vice versa) to compensate for this behavior, which feels counterintuitive and goes against the literal meaning of the variable names.
Is there a more elegant or idiomatic way to handle this in Igor Pro?
Here is the MWE in Igor Pro:
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
Function heatmap()
// == Input Wave ==
SetRandomSeed 3389
make/O/N=(3,5) heatmapData = gnoise(1)
// == Imaging ==
Variable numRow = DimSize(heatmapData, 0);
Variable numCol = DimSize(heatmapData, 1);
Make/O/N=(numCol,numRow) heatmapDataTransposed = heatmapData[q][p]
printf "(Debug) numRow: %d, numCol: %d\n", numRow, numCol
Display
AppendImage heatmapData
ModifyImage heatmapData ctab= {*,*,Rainbow,0}
make/O/N=(numCol) xTick = p
make/O/N=(numRow) yTick = p
Make/O/T/N=(numCol) xTickLabel
Make/O/T/N=(numRow) yTickLabel
Variable row, col
String xTickStr, yTickStr
for(col = 0; col < numCol; col++)
sprintf xTickStr, "X%d", col
xTickLabel[col] = xTickStr
for(row = 0; row < numRow; row++)
sprintf yTickStr, "Y%d", row
yTickLabel[row] = yTickStr
ModifyGraph userticks(left)={xTick,xTickLabel}
ModifyGraph userticks(bottom)={yTick,yTickLabel}
ModifyGraph width={Aspect,1}
SetAxis/A/R left
ColorScale/C/N=text0/F=0/Z=1/B=1/A=RC/E image=heatmapData,axisRange={-2,2}
Variable xAttach
String tagName, textLabel
for (col=0; col < numCol; col++)
for (row = 0; row < numRow; row++)
xAttach = Sub2Ind({numRow, numCol}, {row, col})
sprintf tagName, "tag_%d_%d", row, col
sprintf textLabel, "%0.2f", heatmapData[row][col]
print tagName, xAttach, textLabel
Tag/C/N=$(tagName)/F=0/B=1/Z=1/X=0.00/Y=0.00/L=0 heatmapData, xAttach,textLabel
Function Sub2Ind(dimSizes, indices)
// dimSizes: 1D wave of sizes, e.g. {3,4,5}
// indices: 1D wave of 0-based subscripts, e.g. {1,2,0}
// Returns: 0-based linear index (column-major order)
Wave dimSizes, indices
Variable numDimensions = numpnts(dimSizes)
Variable numIndices = numpnts(indices)
if (numIndices != numDimensions)
Abort "Number of indices must match number of dimensions"
Variable i
String errorMessageStr
// Check for out-of-bounds indices
for (i = 0; i < numDimensions; i += 1)
if (indices[i] < 0 || indices[i] >= dimSizes[i])
sprintf errorMessageStr, "Index out of bounds: indices[%d] = %d, expected 0 to %d", i, indices[i], dimSizes[i] - 1
Abort errorMessageStr
Variable linearIndex = 0
Variable stride = 1
linearIndex += indices[i] * stride
stride *= dimSizes[i]
return linearIndex
For comparison, here's a Python version using `matplotlib` that produces the expected result.
(Note: The random values differ, possibly due to different random number generators, but that’s not a concern.)
import numpy as np
import matplotlib.pyplot as plt
def heatmap_demo():
# Generate data
np.random.seed(3389)
data = np.random.normal(loc=0.0, scale=1.0, size=[3, 5]) # Shape: (rows, columns)
print(data)
# Define labels
num_rows, num_cols = data.shape
x_labels = [f"X{i + 1}" for i in range(num_cols)]
y_labels = [f"Y{i + 1}" for i in range(num_rows)]
# Create the heatmap
fig, ax = plt.subplots()
im = ax.imshow(data, cmap='rainbow')
# Set axis ticks
ax.set_xticks(np.arange(num_cols))
ax.set_yticks(np.arange(num_rows))
# Set tick labels
ax.set_xticklabels(x_labels)
ax.set_yticklabels(y_labels)
# Rotate x-axis labels if needed
plt.setp(ax.get_xticklabels(), rotation=0, ha="center", va="top")
# Add text annotations
for i in range(num_rows):
for j in range(num_cols):
text = f"{data[i, j]:.2f}"
ax.text(j, i, text, ha="center", va="center", color="black")
# Make layout tight and show
plt.title("Heatmap with Custom Tick Labels")
plt.colorbar(im)
plt.tight_layout()
plt.show()
def main():
heatmap_demo()
if __name__ == "__main__":
main()
what about if you change the make command to:
May 7, 2025 at 06:32 am - Permalink
You may be confused by the table and the image representations of an array within Igor. Note that the 'rows' are always displayed on the horizontal / x axis both in image and line plots while columns run along the vertical / y axis (unless you deliberately swap axes). In a table, however, the representation is flipped, i.e., rows always run vertical and columns horizontal in a table. This has apparently historic reasons, about which you can read more here:
https://www.wavemetrics.com/forum/general/translating-matlab-matrix-mul…
May 7, 2025 at 09:14 am - Permalink
In reply to what about if you change the… by ChrLie
guoqilinThank you for your reply! I worked around the issue in a similar way by using
heatmapDataTransposedinstead ofheatmapData, which makes me feel better.May 8, 2025 at 05:41 am - Permalink
In reply to You may be confused by the… by chozo
guoqilinThank you for clearing that up.
May 8, 2025 at 05:44 am - Permalink
