Commentize/Decommentize Keyboard Shortcuts
jjweimer
Sun, 11/22/2009 - 09:47 am
Having Command-{ and Command-} (with corresponding Windows equivalents) as shortcuts to "Commentize" and "Decommentize" procedure code blocks would be useful. (Also, I have always preferred the menu commands Comment and Uncomment as found in TeXShop on MacOS over the above phrasings).
Command-| (the vertical bar character) for "Adjust Indentation".
November 23, 2009 at 12:57 am - Permalink
Or am I wrong?
May 11, 2012 at 06:26 am - Permalink
A big part of the problem is that on Windows it is impossible to create an keyboard accelerator using the / key (which is the obvious key to use for this). And on Macintosh we use that key to bring up the Help Browser.
I agree- a shortcut for this is really needed. Maybe in the mythical Igor 7.
May 11, 2012 at 09:17 am - Permalink
Until then it would also help to be able to go more than 1 step back with "undo", have conditional breakpoints or be able to write in debugmode to play a bit with the code while paused.
May 14, 2012 at 03:08 am - Permalink
Yup - seconded. I appreciate extending the debugger like that is pretty full on, but it would be good. However, the multi level undo would be great, even if its just in the coding windows.
May 17, 2012 at 04:14 am - Permalink
