system variable holding numeric results from the command line
I quite often use Igor's command line as a calculator by executing something like this
print 8.314*2000 * ln(0.3)
and almost equally often I want to do another calculation that uses the result of the previous calculation, which currently I need to enter manually.
A variable holding the last numeric result from a command executed on the command line, similar to "ans" in MatLab or "%" in Mathematica would be greatly appreciated.
I see your point. I don't know if Igor will ever have such a thing.
If you think ahead, you can use your own variable:
Variable res=8.314*2000 * ln(0.3);print res
Now use res in subsequent computations.
johnweeks wrote: I see your point. I don't know if Igor will ever have such a thing.
How about a print/C flag that "captures" the output to a variable V_print?
--> print/C 2*3
---- 6
--> print/C v_print*3
--- 18
--> print 5*5
--- 25
--> print v_print*2
--- 36
Unfortunately, Print/C is already reserved for printing numeric expressions as complex. /S, although obsolete, is also reserved.
s.r.chinn wrote: Unfortunately, Print/C is already reserved for printing numeric expressions as complex. /S, although obsolete, is also reserved.
Oh ... print/V (print to variable) is open!
