Show Graph with Percent Values
hegedus
Tue, 06/03/2014 - 07:16 am
I have data that goes from 0 to 1.0 (fraction of total) and while scientific types are comfortable with that nomenclature, the more business types really want to see the values as %. For Example: instead of 0.64 the graph would show 64%.
Can I do this without having to create a dummy wave? In other programs such as JMP, I can define a variable to be formatted as % and when I graph as such the values will be formatted as percentages even though the underlying data is still the proper decimal.
Can I do the same in Igor?
Click the Offset checkbox, which has the perverse action of opening a sub-dialog.
In the Trace Offset dialog, enter 100 for Y Mult.
This is in the Trace Offset dialog because it was really intended as a way to offset a trace in a log axis, but it will do what you want, too.
June 3, 2014 at 10:01 am - Permalink
June 4, 2014 at 07:26 am - Permalink
