hrodstein wrote: True enough. You can use "GetWindow hide" as a workaround.
I also notice, the GetWindow hide and DoWindow/hide=? return 1 or 2 (or 4 I guess on Windows), whereas the DoWindow/hide=N should use 0 or 1 (or 2 on Windows). I needed a bit of playing around to realize the difference is between using the /hide flag to set bit values N and using it to return the actual values 2^N. If I might make suggestions to improve the help portions for these two operations ...
(DoWindow)/HIDE=h Sets hidden state of a window.
h =0: Visible.
h =1: Hidden
h =2: (Windows only) Visible without restoring minimized windows
h =?: Determines hidden state (returned in V_flag as 2^0 = 1 or 2^1 = 2 or 2^2 = 4)(GetWindow)
hide Sets V_Value bit 0(returns V_value=1 or 2)ifwindow or subwindow is hidden.
Sets bit 1(returns V_value=4)if the host window is minimized.
April 15, 2009 at 11:47 pm - Permalink
April 19, 2009 at 07:43 pm - Permalink
