Structure by index
I just had a quick question about structures. Is there a way to reference a structure item using a numerical index? For example, if I want the 5th item in a structure called 's', I'd like to reference it using s[4].
Ben
You can create a structure only with a field defined as an array or with a wave. Is this not what you want?
STRUCTURE myWaveStructure
     variable var[10]
END STRUCTURE
Function ...
     STRUCT myWaveStructure mws
     mws.var[4] = 4.56
If you know the elements size you can do something like:
structure thunk_s
	int32 a
	int32 b
endstructure
structure thunk_res
	int32 res //same type as a and b
endstructure
function thunk_struct()
	struct thunk_s s
	struct thunk_res r
	s.a = -5
	s.b = 5
	make/o/n=1 w_s
	structput/b=0 s, w_s // w_s stores now struct s as a wave in an understandable but not a standard binary form
	variable v_sz = dimsize(w_s,0)/4 //4 is size of the int32 in the wave w_s
	variable i = 0
	do
		duplicate/o/r=[i*4,(i+1)*4-1] w_s, w_0
		structget/b=0 r, w_0
		// do something with r.res, i-th int32 element of stuct s
		print r.res
		i+=1
	while (i != v_sz)
The key functions are
structget
and
structput
. Of course, knowing what is the structure has influenced me in the implementation of the code, maybe you can abstract it away. I don't know how.
best,
_sk
thomas_braun wrote: @_sk: Nice hack!
I tried, and can't let this pass.
Ew. Can't say I agree, and I almost always agree with Thomas! This has all the bad elements of FORTRAN Common blocks, or C unions. I would only use this if there is no other way.
Yeah, it ain't pretty, you can say that again. The implementation is ugly due to
structput
and the way it dumps the struct in the wave. If
structput
were to dump type annotated data, it would've been a thing of beauty™.
Next time.
best,
_sk
@thomas_braun: Cheers
best,
_sk
There is a problem with using StructPut and StructGet - they do not work with reference variables such as WAVE, NVAR, SVAR and DFREF. The reason is that these are effectively pointers and the object pointed to may not exist when StructGet needs to restore them.
They also do not work with Strings because they are implemented internally using pointers to variable-length data.
It is possible to define a structure containing an array of structures and index into that. Here is an example:
Structure SubStruct
	Variable var
EndStructure
Structure MainStruct
	STRUCT SubStruct sub[100]
EndStructure
Function Demo()
	STRUCT MainStruct ms
	Variable i
	for(i=0;i<10; i+=1)
		ms.sub[i].var = i
	for(i=0;i<10; i+=1)
		Print i, ms.sub[i].var
A limitation is that an array of STRUCTs is limited to 100 elements.
thanks for the input everyone. I think @hrodstein wins for the easiest to implement solution. I came across this problem by trying to transcribe some matlab code into Igor. On a similar topic, the ability to list out the elements of a structure, their data types, size, etc. could be pretty useful - maybe a StructInfo command similar to TraceInfo.
bmb wrote: ... On a similar topic, the ability to list out the elements of a structure, their data types, size, etc. could be pretty useful - maybe a StructInfo command similar to TraceInfo.
I agree. This would, I think, allow one to create generic functions to store and retrieve all elements of a structure to and from a data folder without knowing beforehand the details of the structure.
