I just had a quick question about structures. Is there a way to reference a structure item using a numerical index? For example, if I want the 5th item in a structure called 's', I'd like to reference it using s[4].
If you know the elements size you can do something like:
structure thunk_s
int32 a
int32 b
endstructurestructure thunk_res
int32 res //same type as a and bendstructurefunction thunk_struct()struct thunk_s sstruct thunk_res rs.a = -5s.b = 5make/o/n=1 w_s
structput/b=0s, w_s // w_s stores now struct s as a wave in an understandable but not a standard binary formvariable v_sz = dimsize(w_s,0)/4//4 is size of the int32 in the wave w_svariablei = 0doduplicate/o/r=[i*4,(i+1)*4-1] w_s, w_0
structget/b=0r, w_0
// do something with r.res, i-th int32 element of stuct sprintr.res
i+=1while(i!= v_sz)end
The key functions are structget and structput. Of course, knowing what is the structure has influenced me in the implementation of the code, maybe you can abstract it away. I don't know how.
Ew. Can't say I agree, and I almost always agree with Thomas! This has all the bad elements of FORTRAN Common blocks, or C unions. I would only use this if there is no other way.
Yeah, it ain't pretty, you can say that again. The implementation is ugly due to structput and the way it dumps the struct in the wave. If structput were to dump type annotated data, it would've been a thing of beauty™.
There is a problem with using StructPut and StructGet - they do not work with reference variables such as WAVE, NVAR, SVAR and DFREF. The reason is that these are effectively pointers and the object pointed to may not exist when StructGet needs to restore them.
They also do not work with Strings because they are implemented internally using pointers to variable-length data.
It is possible to define a structure containing an array of structures and index into that. Here is an example:
Structure SubStruct
Variable var
EndStructureStructure MainStruct
STRUCT SubStruct sub[100]EndStructureFunction Demo()STRUCT MainStruct ms
Variableifor(i=0;i<10; i+=1)
ms.sub[i].var = iendforfor(i=0;i<10; i+=1)Printi, ms.sub[i].var
endforEnd
A limitation is that an array of STRUCTs is limited to 100 elements.
thanks for the input everyone. I think @hrodstein wins for the easiest to implement solution. I came across this problem by trying to transcribe some matlab code into Igor. On a similar topic, the ability to list out the elements of a structure, their data types, size, etc. could be pretty useful - maybe a StructInfo command similar to TraceInfo.
bmb wrote: ... On a similar topic, the ability to list out the elements of a structure, their data types, size, etc. could be pretty useful - maybe a StructInfo command similar to TraceInfo.
I agree. This would, I think, allow one to create generic functions to store and retrieve all elements of a structure to and from a data folder without knowing beforehand the details of the structure.
January 13, 2018 at 12:48 pm - Permalink
January 13, 2018 at 01:17 pm - Permalink
structgetandstructput. Of course, knowing what is the structure has influenced me in the implementation of the code, maybe you can abstract it away. I don't know how.best,
_sk
January 16, 2018 at 05:32 am - Permalink
January 16, 2018 at 06:26 am - Permalink
I tried, and can't let this pass.
January 16, 2018 at 09:59 am - Permalink
structputand the way it dumps the struct in the wave. Ifstructputwere to dump type annotated data, it would've been a thing of beauty™.Next time.
best,
_sk
January 17, 2018 at 12:55 am - Permalink
@thomas_braun: Cheers
best,
_sk
January 17, 2018 at 01:03 am - Permalink
January 17, 2018 at 09:57 am - Permalink
January 18, 2018 at 06:21 pm - Permalink
January 19, 2018 at 06:01 am - Permalink
January 19, 2018 at 10:37 am - Permalink
