Is it possible to Create a Data Folder using a name contained in a string
Is it possible to Create a Data Folder using a name contained in a string.
From a function I want create, kill, change to a data folder with name of data folder contained in a string. Is this possible and if so how?
Mike G
jtigor
NewDataFolder [/O/S] dataFolderSpec
For dataFolderSpec use $String
NewDataFolder $String
Where String is the name of your string.
hegedus
Hi Mike,
Short answer: yes
Function FutzWithDataFolder(theName,What)
	string theName
	String What
	strswitch (What)	// string switch
		case "Make":	// execute if case matches expression
			NewdataFolder $theName
			break	// exit from switch
		case "Kill":	// execute if case matches expression
			KillDataFolder/Z $theName
			break
	endswitch
I have left the change up to the reader since it requires an additional input.
