Content of Wave Reference Waves
Apologies if I missed an option in the documentation, but is there a way to view the content of wave reference waves, i.e. to see full paths of referenced waves in a table?
If not, could this information maybe be stored as wave note?
You can grab the full path from the wave reference wave yourself as in
Function Dostuff()
	Make/FREE dataFree = p
	Make/O dataPerm = p^2
	Make/O/WAVE container = {dataFree, dataPerm}
	Edit container.ld
	printf "Path %s\r", GetWavesDataFolder(container[0], 2)
	printf "Path %s\r", GetWavesDataFolder(container[1], 2)
which outputs
  Path
  Path root:dataPerm
as only permanent waves have a datafolder where they reside in.
Try this:
Make jack, fred
Make/WAVE ww = {jack, fred}
Edit ww
Now choose Table->Show Column Info Tags.
Now hover the mouse over the two wave elements in the table. The column info tag shows the wave to which the element points.
Thanks Thomas and Howard!
I was looking for an option to quickly see the content based out of the data browser without dealing with commands. The last option kind of works for me but it's not as quick as I wished.
PS: Well, actually something like this works better
#if IgorVersion() >= 9
menu "DataBrowserObjectsPopup"
	"Show Wave References", /Q, ShowWRefWaves()
function ShowWRefWaves()
	string item = GetBrowserSelection(0)
	if (strlen(item) == 0)
	wave/wave/z w=$item
	if(wavetype(w, 1) != 4)
		print "Wrong wave/object type!"
		return -1
	variable i, nPts=numPnts(w)
	for(i=0; i<nPts(w); i++)
		print GetWavesDataFolder(w[i], 2)
	return 1
PPS: "DataBrowserObjectsPopup" --> great feature!!
In reply to by ChrLie
If you want to make this a bit fancier, you can use this code:
Menu "DataBrowserObjectsPopup", dynamic
	// This menu item is displayed if a single wave reference wave is selected
	DisplayWaveRefMenuItemString(), /Q, DisplayWaveReferences()
// If only one wave reference wave is selected in the Data Browser
// object list, this function returns the selected wave
// via w1 and returns 1. Otherwise the function returns 0
// and the w1 parameter may be null.
static Function GetSelectedWaveRefWave(WAVE/Z &w1)
	if (strlen(GetBrowserSelection(-1)) == 0)
		return 0	// Data Browser is not open
	WAVE/Z w1 = $(GetBrowserSelection(0))	// May be null
	if (!WaveExists(w1) || strlen(GetBrowserSelection(1)) > 0)
		return 0		// Too few or too many waves selected
	if (WaveType(w1,1)!=4)
		return 0		// Wave is not a wave reference wave
	return 1
Function/S DisplayWaveRefMenuItemString()
	WAVE/Z w1, w2
	int oneWaveRefWaveSelected = GetSelectedWaveRefWave(w1)
	if (!oneWaveRefWaveSelected)
		return ""
	String menuText
	sprintf menuText, "Show Wave References"
	return menuText
Function DisplayWaveReferences()
	WAVE/Z w1
	if (oneWaveRefWaveSelected)
		WAVE/WAVE w1Ref = w1
		variable i, nPts=numPnts(w1Ref)
		for(i=0; i<nPts; i++)
			WAVE/Z thisWave = w1Ref[i]
			if (WaveExists(thisWave))
				print GetWavesDataFolder(thisWave, 2)
				print "<null>"
#endif		// IP9+
That will cause the "Show Wave References" contextual menu item to be hidden except when only one wave reference wave is selected.
