Mousewheel Graph Window Zoom
Wed, 02/10/2021 - 09:02 am
In my web browser I can magnify the window contents by holding down the command/control key and scrolling with mousewheel or trackpad. Now I can do the same in a graph window :)
You can already use the mousewheel/trackpad to change the axis range if you hover over an axis. The code below lets you zoom both axes simultaneously. Holding down the shift key as well as command/ctrl accelerates the zoom factor. Expansion/contraction is centred at the mouse cursor position, so you can position your mouse and command-shift-scroll to zoom in rapidly on a point of interest.
When the 'global' symbol is defined, scroll-to-zoom is active for all newly created graph windows. Otherwise, it can be tuned on or off for each graph window.
#pragma version=1.30
#pragma ModuleName=ScrollToZoom
#define global
// key codes
// 2: shift; 4: option/alt; 8: command/ctrl
// On Windows, alt key is reserved for graph drag.
static constant kZoomKey=8
static constant kFasterKey=2
static constant kZoomSpeed=70
static constant kReverse=0 // reverse the direction of expansion
#ifdef global
static function AfterWindowCreatedHook(string win, variable type)
if (type == 1)
SetWindow $win hook(hScrollToZoom)=ScrollToZoom#hookScrollToZoom
#else
menu "Graph", dynamic
ScrollToZoom#zoomMenu(), /Q, ScrollToZoom#toggleZoom()
static function /S zoomMenu()
GetWindow kwTopWin hook(hScrollToZoom)
return SelectString(strlen(s_value)>0, "", "!" + num2char(18)) + "Scroll-Zoom"
static function toggleZoom()
SetWindow kwTopWin hook(hScrollToZoom) = $SelectString(strlen(s_value)>0, "ScrollToZoom#hookScrollToZoom", "")
#endif
static function hookScrollToZoom(STRUCT WMWinHookStruct &s)
if (s.eventCode == 22 && s.eventMod&kZoomKey) // mousewheel/touchpad + zoom key
// figure out first horizontal and first vertical axes
string strAxes = AxisList(s.WinName), axis = "", type = "", hAx = "", vAx = ""
int fail = 2, i = 0
int logH, logV
make /D/free/N=3 wH, wV // free waves to hold axis minimum, maximum, axis value for mouse location, reverse axis flag
do
axis = StringFromList(i, strAxes)
type = StringByKey("AXTYPE", AxisInfo(s.WinName, axis))
if (strlen(hAx)==0 && (cmpstr(type, "bottom")==0 || cmpstr(type,"top")==0 || cmpstr(type[0,2],"/B=")==0 || cmpstr(type[0,2],"/T=")==0) )
hAx = axis
logH = NumberByKey("log(x)", AxisInfo(s.WinName, axis),"=")
fail--
elseif (strlen(vAx)==0 && (cmpstr(type, "left")==0 || cmpstr(type,"right")==0 || cmpstr(type[0,2],"/L=")==0 || cmpstr(type[0,2],"/R=")==0) )
vAx = axis
logV = NumberByKey("log(x)", AxisInfo(s.WinName, axis),"=")
fail--
i++
while ( strlen(type) && (strlen(hAx)==0 || strlen(vAx)==0) )
if (fail)
// It would be nice if GetAxis and SetAxis could accept a shorthand for
// first horizontal or first vertical axis.
// AxisValFromPixel is more flexible.
GetAxis /W=$s.WinName/Q $hAx
wH = {v_min, v_max, AxisValFromPixel(s.WinName, hAx, s.mouseLoc.h), v_min>v_max}
GetAxis /W=$s.WinName/Q $vAx
wV = {v_min, v_max, AxisValFromPixel(s.WinName, vAx, s.mouseLoc.v), v_min>v_max}
wH = logH ? log(wH) : wH
wV = logV ? log(wV) : wV
int rev=1-2*kReverse
variable expansion = 1 - rev*s.wheelDy * kZoomSpeed/5000
if (s.eventMod&kFasterKey)
if (kFasterKey==2 && s.wheelDy==0)
// this works when shift key also transforms wheel.dY to wheel.dX
s.wheelDy = s.wheelDx
wH[0,1] = wH[2] - (wH[2] - wH[p]) * expansion
wV[0,1] = wV[2] - (wV[2] - wV[p]) * expansion
wH = logH ? alog(wH) : WH
wV = logV ? alog(wV) : wV
// what can go wrong here?
wavestats /Q/M=1 wH
fail += V_numNaNs + V_numInfs
wavestats /Q/M=1 wV
if (fail + V_numNaNs + V_numInfs)
if(wH[1]==wH[0] || wV[1] == wV[0])
// here we include a check that the axis direction does not become
// reversed owing to some glitch in the calculation at extreme zoom
// levels
if (wH[1] > wH[0] && !wH[3])
SetAxis /W=$s.WinName $hAx, wH[0], wH[1]
elseif (wH[3])
SetAxis /R/W=$s.WinName $hAx, wH[0], wH[1]
if (wV[1] > wV[0] && !wV[3])
SetAxis /W=$s.WinName $vAx, wV[0], wV[1]
elseif (wV[3])
SetAxis /R/W=$s.WinName $vAx, wV[0], wV[1]
Igor Pro 8
Edited snippet works with log axes.
February 17, 2021 at 12:30 am - Permalink
Edited to add /R flag for reversed axes. A subsequent autoscale will not switch the axis direction.
February 19, 2021 at 04:27 am - Permalink
