Lispix format
ChrLie
Tue, 12/14/2010 - 11:45 am
Is there any possibility to import raw-files in Lispix format into Igor:
https://www.nist.gov/services-resources/software/lispix
I would like to use Igor to handle "cube" data sets acquired from electron microscopy, which would be equivalent to 3D-waves, e.g. of the size "Make/B/U/N=(500, 500, 1024) cube". Those data are generated by spectral imaging, where each pixel of an image contains an energy dispersive spectrum.
Any ideas or suggestions how to import such data would be highly appreciated!
Cheers
Christian
GBLoadWave
is your friend.You could first extract the parameters from the .rpl file using, e.g., Open, FReadLine and sscanf, and then use that information as input for the GBLoadWave operation. The nomenclature ("little-endian" etc.) is exactly the same in GBLoadWave and the documentation links you posted.
Wolfgang Harneit
December 14, 2010 at 03:54 pm - Permalink
// adds a new menu to the right of the help menu
Menu "Lispix Support"
"Import Lispix Files"
// to be called by user (e.g., through menu)
function/S ImportLispixFiles()
variable refNum
Open/D/R/T=".rpl"/M="Select one or more ripple (.rpl) files"/MULT=1 refNum
string filePaths = S_fileName
if( strlen(filePaths) == 0 )
print "user cancelled."
variable i, numFilesSelected = ItemsInList(filePaths, "\r")
for( i = 0; i < numFilesSelected; i += 1 )
string path = StringFromList(i, filePaths, "\r")
ReadLispixFilePair(path)
return filePaths
// to be called by ImportLispixFiles()
function ReadLispixFilePair(ripplePath)
string ripplePath // known to be a valid path to a ripple (.rpl) file
// 1. make sure there is an associated raw file, get its name
string rawPath = ripplePath[0,strlen(ripplePath)-3] + "aw"
GetFileFolderInfo/Q/Z rawPath
if( V_Flag != 0 )
print "no raw file found for "+ParseFilePath(0, ripplePath, ":", 1, 0)
// 2. read ripple file, convert to keyword-value string
variable refNum
Open/R refNum as ripplePath
string info = ""
do
string line
FReadLine refNum, line
if( strlen(line) == 0 ) // end of file
break // exit do-while loop
if( !cmpstr(line[0],";") ) // comment line
continue // skip
line = ReplaceString(" ", LowerStr(line), "") // remove spaces and convert to lower case
string keyStr, valStr
sscanf line, "%s %s", keyStr, valStr
info += keyStr + ":" + valStr + ";" // convert to Igor-style keyword-value string
while( 1 ) // exit is through break statement
Close refNum
// 3. extract info from keyword-value string
variable offset = NumberByKey("offset", info), byteOrder = 0
if( !cmpstr(StringByKey("byte-order", info), "little-endian") )
byteOrder = 1
variable igorType = 0, length = NumberByKey("data-length", info)
string dataType = StringByKey("data-type", info)
strswitch(dataType)
case "float":
if( length == 4 || length == 8 )
igorType = length/2
break
case "unsigned":
igorType = 64
// fall through
case "signed":
if( length == 1 || length == 2 || length == 4 )
igorType += 8*length
igorType = 0
break
endswitch
if( igorType == 0 )
abort "illegal data type/length specification: "+dataType+"/"+num2str(length)
// 4. load raw file
GBLoadWave /A=lispix /B=(byteOrder) /Q /S=(offset) /T={igorType,igorType} rawPath
// 5. report to history and rename wave to filename
if( V_flag == 0 )
printf "no waves"
printf S_waveNames
print " loaded from "+S_path+S_fileName+"."
if( V_Flag == 1 ) // should be one
string oldName = StringFromList(0, S_waveNames)
string newName = ParseFilePath(3, ripplePath, ":", 0, 0)
wave oldWave = $oldName
Duplicate/O oldWave, $newName
KillWaves oldWave
print oldName+" renamed to "+newName
// 6. redimension data cube
variable width = NumberByKey("width", info)
variable height = NumberByKey("height", info)
variable depth = NumberByKey("depth", info)
Redimension/N=(width, height, depth) $newName
// 7. set data scaling
SetScale/P X, 0, 1, "Å", $newName
SetScale/P Y, 0, 1, "Å", $newName
if( !cmpstr(StringByKey("record-by", info), "vector") )
variable Zscale = NumberByKey("ev-per-chan", info)
SetScale/P Z, 0, Zscale, "eV", $newName
SetScale/P Z, 0, 1, "Å", $newName
December 14, 2010 at 06:30 pm - Permalink
Hi Wolfgang,
thanks for pointing me towards GBLoadWave! I feel quite guilty now, seeing that you wrote this code apparently between 2 and 4 a.m.!
Thanks for your effort - using this I got some test data imported straight away, although it looks different to what I expected - I will look more carefully at the parameters!
Thanks again,
Cheers
Christian
December 15, 2010 at 08:07 am - Permalink
Wolfgang
December 15, 2010 at 09:57 am - Permalink
Cheers
Christian
December 15, 2010 at 10:55 am - Permalink
assumes that the data in the file is stored in "column major order" (see http://en.wikipedia.org/wiki/Row-major_order).
For a matrix, this means that, as you sequentially step through memory, all of the elements for column 0 appear consecutively, then all of the elements for column 1, and so on. Column major order is used by Igor and, according to the wikipedia article, by Fortran and Matlab.
C and many programs use row major order. For a matrix this means that, as you sequentially step through memory, all of the elements for row 0 appear consecutively, then all of the elements for row 1, and so on.
I'm a bit unclear on how this translates to 3D.
If your data is in row major order then you will need to shuffle it to put it in the right order. You would do this by duplicating it to create a temporary wave and then using wave assignment statements to pick the data out of the temporary wave and put it in the output wave in the right order.
December 15, 2010 at 01:52 pm - Permalink
it seems that this is likely the problem, because the imported 3D wave shows some regular patterns such that rows, columns or layers might have been mixed up.
I will start with a 1D wave and try to figure out the order.
Thanks
Christian
December 15, 2010 at 10:41 pm - Permalink
Redimension/N=(depth,width,height) $newname
for vector cubes. Then, you would have images in the YZ dimensions, and the X dimension represents the spectra. I guess you would want XY as image dimensions and Z as the spectral dimension. This could be achieved by leaving the Redimension line as it is and then picking out the data with
newWave[][][] = oldWave[(p + q*width)*depth + r]
or so. Of course, in any case you'd have to modify the surrounding code a bit (e.g. defer the
KillWaves oldWave
statement, declareWave NewWave= $newName
, etc.)Wolfgang
December 16, 2010 at 10:13 am - Permalink
Last week I completed a hack to load raw WiRE files (proprietary filetype used in Renishaw Raman spectrometers, may hold 1d or 2d arrays of spectra and spatial coordinates). Jamie Boyd's BinaryReader procedure was indispensable for figuring out the structure of the binary files. I've used it to hack several file types, including Bruker FTIR files. If you haven't already tried it, you should check it out!
Edit: Oops, I just realized that this is an old thread that was resurrected when links were fixed. Still, I recommend BinaryReader to anyone reading this!
July 27, 2018 at 08:01 am - Permalink
