Save All Graphs for IP9
Inspired by a code snippet for IP7 posted here, I've worked up a modified version. The snippet below has been tested under IP9. It will show as a menu option in the Macros menu. It takes various modifier keystrokes during the menu call to determine whether to include hidden graphs (default is only visible), store with title (default is with name), or store as PDF (default is PNG).
I commented out many of the print error messaging lines in the main code simply to keep a cleaner operation. I will use this code snippet as part of my "always loaded" functions.
DISCLAIMER: I used Claude AI for recommendations to clean up some of the coding.
Menu "Macros", dynamic SaveGraphMenuString(), /Q, Do_SaveAllGraphs() end Function/S SaveGraphMenuString() string rStr variable nvgraphs, nhgraphs nvgraphs = ItemsInList(WinList("*",";","WIN:1;VISIBLE=1")) if (nvgraphs == 0) rStr = "\\M1(Save All Graphs" else nhgraphs = ItemsInList(WinList("*",";","WIN:1")) - nvgraphs sprintf rStr,"Save All Graphs (%d |%2.0f)", nvgraphs, nhgraphs endif return rStr end Function Do_SaveAllGraphs() variable keystate = GetKeyState(0) variable ngraphs string rStr // 16 - control // 4 - shift // 2 - option // 1 - command switch(keystate) case 1: // command key - include hidden ngraphs = SaveAllGraphs(H=1) break case 2: // option key - use title ngraphs = SaveAllGraphs(T=1) break case 4: // shift key - PDF ngraphs = SaveAllGraphs(F=1) break default: // no key ngraphs = SaveAllGraphs() break endswitch PathInfo graphs sprintf rStr, "%s - %s: saved %d graph(s) to %s", date(), time(), nGraphs, s_path print rStr return 0 end // M is match string (default "*") // P is Igor path name as string (default "home") // T = 0 use name (default), T = 1 use title // H = 0 do not include hidden (default), H = 1 include hidden // F = 0 store as PNG (default), F = 1 store as PDF function SaveAllGraphs([string M, string P, variable T, variable H, variable F]) variable ic, nGraphs, sv string graphList, currWindow, fname // set defaults M = SelectString(ParamIsDefault(M), M, "*") T = ParamIsDefault(T) ? 0 : T H = ParamIsDefault(H) ? 0 : H F = ParamIsDefault(F) ? 0 : F // get graph list based on hidden flag graphList = WinList(M, ";", "WIN:1" + SelectString(H, ";VISIBLE:1", "")) nGraphs = ItemsInList(graphList) if (nGraphs == 0) print "No graphs found matching criteria." return 0 endif // define the path if (ParamIsDefault(P)) PathInfo home if (V_flag == 0) // Check if path exists // print "Warning: 'home' path not found. Using current directory." GetFileFolderInfo/Q/Z "" endif else PathInfo $P if (V_flag == 0) // Path doesn't exist // print "Warning: Path '" + P + "' not found. Using 'home' instead." PathInfo home if (V_flag == 0) // Check if path exists // print "Warning: 'home' path not found. Using current directory." GetFileFolderInfo/Q/Z "" endif endif endif NewPath/C/O/Q graphs, S_path + "graphs:" // set save format and resolution if (F == 0) // PNG sv = -5 // 150 DPI else // PDF sv = (cmpstr(IgorInfo(2), "Windows") == 0) ? -8 : -2 endif string fileExt = SelectString(F, ".png", ".pdf") // save all graphs for (ic = 0; ic < nGraphs; ic += 1) currWindow = StringFromList(ic, graphList) // Get filename from window name or title if (T == 0) fname = CleanUpName(currWindow, 1) else GetWindow $currWindow, wtitle fname = CleanUpName(S_value, 1) endif // save the graph SavePICT/O/E=(sv)/P=graphs/WIN=$currWindow as fname + fileExt endfor return nGraphs end
