Igor Pro 7 Macro: Batch Save All Graphs as PNGs
I’ve seen many different scripts shared for saving graphs from the Procedure window in Igor Pro, and I wanted to create a more streamlined and reusable version. So I refined them and packaged everything into a simple macro you can easily add to your Igor Pro setup.
This macro is mostly based on the procedure introduced by Tony Withers, with a few improvements and refinements for clarity and ease of use.
I developed and tested this on Igor Pro 7 for Windows, but it might work on other versions as well; feel free to try it and let me know!
What It Does:
This macro allows you to save all open graphs at once as .png files in a subfolder called Graphs located in the same directory as your .pxp file.
There are two functions you can use:
SaveAllGraphsN()— Saves graphs using their window names. (Will override files if names repeat.) -
SaveAllGraphsT()— Saves graphs using their titles. (Will prompt for a new name if duplicate titles are found.)
Usage Instructions:
Open the Procedure Window in Igor Pro.
Paste the following code.
Compile it.
Or:
To have the function in all of your projects,save the macro (.ipf)file and place it in:
This PC\Documents\WaveMetrics\Igor Pro 7 User Files\Igor Procedures
To quickly access that folder, go to Help > Show Igor Pro User Files inside Igor.
Once it’s installed, simply run one of the commands mentioned, in the Igor command line.
code:
// Procedure 1:
// Save graphs using their window "Name"
// WARNING: This will override files with the same name
function SaveAllGraphsN()
int NGraphs, i
string graphList, currWindow
graphList = WinList("*", ";", "WIN:1")
NGraphs = ItemsInList(graphList)
PathInfo home
NewPath/C/O/Q graphs, S_path + "graphs:"
for (i = 0; i < NGraphs; i += 1)
currWindow = StringFromList(i, graphList)
GetWindow $currWindow, wtitle
SavePICT/O/E=-5/P=graphs/WIN=$currWindow as currWindow + ".png"
// Procedure 2:
// Save graphs using their "Title"
// WARNING: Make sure your titles don’t contain "/" or parentheses
// If you're sure there are no duplicate titles, you can add \O to the SavePICT line to override
function SaveAllGraphsT()
int NGraphs, i
PathInfo home
SavePICT/E=-5/P=graphs/WIN=$currWindow as CleanUpName(s_value, 1) + ".png"
After consideration and with due respect to the IP7 thrust for the code snippet posted here, I've moved my code snippet to a different thread. I want to avoid any confusion should certain portions of what I posted be inclined to fail under IP7.
I appreciate the inspiration!
August 7, 2025 at 02:28 pm - Permalink
