Save All Graphs for IP9
Inspired by a code snippet for IP7 posted here, I've worked up a modified version. The snippet below has been tested under IP9. It will show as a menu option in the Macros menu. It takes various modifier keystrokes during the menu call to determine whether to include hidden graphs (default is only visible), store with title (default is with name), or store as PDF (default is PNG).
I commented out many of the print error messaging lines in the main code simply to keep a cleaner operation. I will use this code snippet as part of my "always loaded" functions.
DISCLAIMER: I used Claude AI for recommendations to clean up some of the coding.
Menu "Macros", dynamic
	SaveGraphMenuString(), /Q, Do_SaveAllGraphs()
Function/S SaveGraphMenuString()
	string rStr
	variable nvgraphs, nhgraphs
	nvgraphs = ItemsInList(WinList("*",";","WIN:1;VISIBLE=1"))
	if (nvgraphs == 0)
		rStr = "\\M1(Save All Graphs"
		nhgraphs = ItemsInList(WinList("*",";","WIN:1")) - nvgraphs
		sprintf rStr,"Save All Graphs (%d |%2.0f)", nvgraphs, nhgraphs
	return rStr
Function Do_SaveAllGraphs()
	variable keystate = GetKeyState(0)
	variable ngraphs
	string rStr
	// 16 - control
	// 4 - shift
	// 2 - option
	// 1 - command
	switch(keystate)
		case 1:		// command key - include hidden
			ngraphs = SaveAllGraphs(H=1)
			break
		case 2:		// option key - use title
			ngraphs = SaveAllGraphs(T=1)
			break
		case 4:		// shift key - PDF
			ngraphs = SaveAllGraphs(F=1)
			break
		default:	// no key
			ngraphs = SaveAllGraphs()
			break
	endswitch
	PathInfo graphs
	sprintf rStr, "%s - %s: saved %d graph(s) to %s", date(), time(), nGraphs, s_path
	print rStr
// M is match string (default "*")
// P is Igor path name as string (default "home")
// T = 0 use name (default), T = 1 use title
// H = 0 do not include hidden (default), H = 1 include hidden
// F = 0 store as PNG (default), F = 1 store as PDF
function SaveAllGraphs([string M, string P, variable T, variable H, variable F])
	variable ic, nGraphs, sv
	string graphList, currWindow, fname
	// set defaults
	M = SelectString(ParamIsDefault(M), M, "*")
	T = ParamIsDefault(T) ? 0 : T
	H = ParamIsDefault(H) ? 0 : H
	F = ParamIsDefault(F) ? 0 : F
	// get graph list based on hidden flag
	graphList = WinList(M, ";", "WIN:1" + SelectString(H, ";VISIBLE:1", ""))
	nGraphs = ItemsInList(graphList)
	if (nGraphs == 0)
		print "No graphs found matching criteria."
	// define the path
	if (ParamIsDefault(P))
		PathInfo home
		if (V_flag == 0)  // Check if path exists
			// print "Warning: 'home' path not found. Using current directory."
			GetFileFolderInfo/Q/Z ""
		PathInfo $P
		if (V_flag == 0)  // Path doesn't exist
			// print "Warning: Path '" + P + "' not found. Using 'home' instead."
			PathInfo home
	NewPath/C/O/Q graphs, S_path + "graphs:"
	// set save format and resolution
	if (F == 0)  // PNG
		sv = -5  // 150 DPI
	else  // PDF
		sv = (cmpstr(IgorInfo(2), "Windows") == 0) ? -8 : -2
	string fileExt = SelectString(F, ".png", ".pdf")
	// save all graphs
	for (ic = 0; ic < nGraphs; ic += 1)
		currWindow = StringFromList(ic, graphList)
		// Get filename from window name or title
		if (T == 0)
			fname = CleanUpName(currWindow, 1)
			GetWindow $currWindow, wtitle
			fname = CleanUpName(S_value, 1)
		// save the graph
		SavePICT/O/E=(sv)/P=graphs/WIN=$currWindow as fname + fileExt
	return nGraphs
