Automatically label axes according to the plotted waves or trace names
Run autoLabelAxes(symbol=2) to label all axes by their trace names.
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access
#pragma DefaultTab={3,20,4} // Set default tab width in Igor Pro 9 and later
// Label all axes according to the plotted trace, iff one trace is plotted.
function autoLabelAxes([symbol])
// If two traces are plotted, no change is made to the label.
// variable symbol : Adds the legend symbol of the trace as well.
// Bar charts and fancy colours are not supported.
// Adapted from autoColourAxes() by jcc on 170724.
// autoLabelAxes() // axes labelled with "\c" (wave name)
// autoLabelAxes(symbol=1) // axes labelled with "symbol and trace name" (like Legend)
// autoLabelAxes(symbol=2) // axes labelled with "trace name" (like Legend but no symbol)
variable symbol
// 1. Use tracerepeat() to get trace list
string visibleTraces= TraceNameList("", ";", 2^0 + 2^1 + 2^2)
string topwin= winList("*","","WIN:")
variable i, n_traces= itemsInList(visibleTraces)
variable n_axes= itemsinList(AxisList(topwin))
string cmd
string nxLabel
string pastAxes= ""
string unchangedList= ""
if (n_traces==1)
// don't bother with symbols when one trace
symbol=0
elseif (paramIsDefault(symbol) && (n_axes-1)<3)
// just a couple axes, do it
symbol=1
elseif (paramIsDefault(symbol) && strlen(getSmartSortedAxisList(type="right", win=topwin)) && strlen(getSmartSortedAxisList(type="left", win=topwin)))
// opposite sided axes, do it
symbol=1
// somehow this command is orphaned....
if (GrepString(AxisList(topwin), "bottom"))
Label bottom, "\\c"
print ""
// uando print "bottom/top axes not handled properly by autolabelaxes() 180420....also slash TN tracenames"
for (i=0; i<n_traces; i+=1)
// 2. use TraceInfo to get trace axes & trace colour (via TraceInfo)
string nxTrace= stringFromList(i, visibleTraces)
string nxtInfo= TraceInfo(topwin, nxTrace, 0) // also works, but less controlled: TraceInfo("", "", 1)
nxtInfo= replaceString("RECREATION:", nxtInfo, "") // list goes: RECREATION:zColor(x)=[..];zColorMin(x)=[..];[..] so this allows 1st item retrieval
string nxtAxis, nxtAxisFlag= StringByKey("AXISFLAGS", nxtInfo)
strswitch (nxtAxisFlag)
case "": // means "/L":
nxtAxis= "left"
break
case "/R":
nxtAxis= "right"
break
default:
nxtAxis= stringFromList(1, nxtAxisFlag,"/")[2,inf] // -> custom, like " /L=customAxis"...omit the /L= and the following /B= stringFromList(1, nxtAxisFlag,"/")
endswitch
string currLabel= AxisLabelText(topwin, nxtAxis)
// check if axis was already treated
variable alreadyTreated= strlen(grepList(pastAxes, nxtAxis))
if (alreadyTreated && !symbol)
elseif (alreadyTreated && symbol)
if (symbol)
// update existing label
if (symbol==2)
nxLabel= "\\JL\\r" + currLabel + nxTrace
nxLabel= "\\JL\\r" + currLabel + "\\r\s("+nxTrace+") " + nxTrace
// revert to previous label
currLabel= grepList(unchangedList, nxtAxis) // REDUNDANT?? never used...
nxLabel= currLabel
// build new label
if (symbol)
if (symbol==2)
nxLabel= nxTrace
nxLabel= "\s("+nxTrace+") " + nxTrace
nxLabel= "\\c"
pastAxes+= nxtAxis
unchangedList+= currLabel
// check if wave symbols were already coloured (zcolor)
string thisZcol= StringByKey("zcolor(x)", nxtInfo, "=", ";")
variable zColourOn= cmpstr(thisZcol,"0")!=0
if (zColourOn && symbol && 0 && 0 && 0)
// TODO/future feature.... change marker/line to black, so symbols aren't confusing
// 3. apply trace colour to trace axis
sprintf cmd, "Label %s \"%s\"", nxtAxis, nxLabel
execute cmd
// 4. if axis has been coloured before, make black (if really want to waste time programming, add a coloured box to trace label for each colour (Signal [RED] [BLUE])
return 1
// Get a sorted list of left//right//bottom//top axes. Internal function.
function /s getSmartSortedAxisList([type, win, defaultAxFirst])
string type // "left", "right", "bottom", or "top" (== AXTYPE from AxisInfo())
string win
variable defaultAxFirst// put axis named "left" at top of list of left axes, etc
if (ParamIsDefault(win))
win= ""
// check existence of window
GetWindow /Z $win wtitle
if (V_flag != 0)
return "" // no window found
// get and prune axis list
string allAxes = AxisList(win)
string axes = ""
// return axes of this type only
variable i,n=itemsInList(allAxes)
for (i=0; i<n; i+=1)
string thisAxis= stringFromList(i,allAxes)
string thisAxType= StringByKey("AXTYPE", AxisInfo(win, thisAxis))
if (stringmatch(thisAxType, type))
// put default axis first
if (stringmatch(thisAxis, type))
axes = thisAxis + ";" + axes
axes += thisAxis + ";"
// were any axes found?
if (!strlen(axes))
return ""
// sort axes according to their current order, if one exists (no special treatment of 'left')
n=itemsInList(axes)
variable enab0, enab1
string ax, axEnabStr
make /free /n=(n) enab0w, enab1w, d_enab
make /free /T /n=(n) axNames
// get all ranges
ax= stringFromList(i,axes)
axEnabStr= stringByKey("axisEnab(x)", AxisInfo(win, ax), "=", ";")
sscanf axEnabStr, "{%g,%g}", enab0, enab1
axNames[i]= ax
enab0w[i]= enab0
enab1w[i]= enab1
Sort enab0w, axNames, enab1w, enab0w // sort by start positions
d_enab= enab1w[p] - enab0w[p] // check if overlap 1/2
if (waveMin(d_enab) >= 0) // check if overlap 2/2
// no overlap: sort axes
axes= textwave2list(axNames)
// either something weird, or no sort exists yet
return axes
// GRABBED FROM #include <Axis Utilities> VIA http://www.igorexchange.com/node/603
// Returns the text of the axis label.
// If optional parameter SuppressEscaping is non-zero, extra backslashes ("\\" is required
// to include a single backslash in a quoted string) are removed
// so that the result is a string suitable to be passed directly to the Label operation.
STATIC Function/S AxisLabelText(graphName, axisName, [SuppressEscaping])
String graphName, axisName
Variable SuppressEscaping
if (ParamIsDefault(SuppressEscaping))
SuppressEscaping = 0
String axisLabel=""
String info= WinRecreation(graphName,0)
Variable start= strsearch(info, "Label "+axisName, 0)
if( start >= 0 )
start = strsearch(info, "\"", start)+1
Variable theEnd= strsearch(info, "\"", start)-1
axisLabel= info[start,theEnd]
if (SuppressEscaping)
start = 0
do
start = strsearch(axisLabel, "\\\\", start) // search for double backslash
if (start >= 0)
string newLabel = axisLabel[0,start-1]
newLabel += axisLabel[start+1, strlen(axisLabel)-1]
axisLabel = newLabel
break
while(1)
return axisLabel
// Given a text wave reference, returns a string-list formatted version of the wave.
function/s textwave2list(w[, sep])
// printed using %s.
// e.g. make /T w={"a","b","c"}; print textwave2list(w) returns "a;b;c"
wave /T w
string sep // optionally specify list delimiter
if (ParamIsDefault(sep))
sep=";"
if (!WaveExists(w) || numpnts(w)==0)
return ""
string str
wfprintf str, "%s;", w
return str
