lognormal fitting
the problem: i have an xy data set that looks like a nice lognormal distribution. however, when i fit a get this ridiculously high chi-square value, which does not mean anything because i do not have a weighting wave -nor will i have one.
the question: which is a general question for fitting - how can i evaluate goodness of fitting without a weighting wave? is there something like a kolmogorov test that i can do (or anything else)? how? i mean, the xy data set comes from two different waves, and cannot be compared to the fitted function, which is just a single wave. If i try to interpolate the xy set to a single wave, i get meaningless waves. what am i doing wrong?
cheers
P
August 23, 2010 at 03:54 pm - Permalink
But if the X values are not sorted, interpolate will give pretty weird results. Also, if you have NaN's (Not a Number, or a blank cell) in your data, you will get local patches within the interpolated data that are NaN's.
[/quote]
The Interpolate2 operation (Analysis->Interpolate) automatically sorts input data and removes NaNs before doing the interpolation.
[quote]
I believe the cubic spline interpolator (Interpolate... at the bottom of the Analysis menu) will fail completely with NaN's under some cirumstances.
[/quote]
Only in the "X Coords From Dest Wave" mode when the destination is an XY pair and the X destination wave contains NaNs. This is very rare. The next release of Interpolate2 will tolerate the NaNs in this situation.
August 23, 2010 at 07:18 pm - Permalink
Then plot the Y wave of model values against the Y wave of data values, while is called a Q-Q plot (for Quantile-Quantile). The closer this line is to a straight line with slope=1, the better the fit. That gives you a visual assessment of fit. A Kolmorgov-Smirnov test (StatsKSTest) of the two waves (model values and data values) will assess this statistically.
August 23, 2010 at 09:16 pm - Permalink
thanks for the help. the newwave and kolmogorov-smirnov solved the problem. this forum is very helpful.
i am still troubled by the weighting function. how can i get one? actually, i do not even know what the residuals are.
the reduced chisqr looks ok, but how do a get the degrees of freedom? it is not going to be N-2 if my data set is over 1000 points.
P
August 24, 2010 at 06:56 am - Permalink
[/quote]Residuals are the difference between the fitted model and the Y data. It's what's left over that wasn't accounted for by the model.[quote]
the reduced chisqr looks ok, but how do a get the degrees of freedom? it is not going to be N-2 if my data set is over 1000 points.[/quote]No, it will be N-4 because the built-in LogNormal fitting function has four coefficients.
August 24, 2010 at 04:26 pm - Permalink
