3D Representation of H Atom Orbitals
The following code generates different representations of the real H atom orbitals. The wave function and the wave function squared are represented as isosurfaces in different Gizmo plots. The sign of the wave function is represented by color (i.e., blue and red isosurfaces). In a different window, a Monte Carlo simulation is used to generate a probabilistic point cloud representation of the wave function. Graphs of the radial wave function are also generated.
The isosurfaces may need to be tweaked. For people not used to the Gizmo interface, this can be accomplished with the Modify Isosurface macro.
Code to generate the Bohr orbitals is also included.
Sample images are shown after the code.
#pragma TextEncoding = "UTF-8" #pragma rtGlobals=3 // Use modern global access method and strict wave access #pragma DefaultTab={3,20,4} // Set default tab width in Igor Pro 9 and later // Procedures to generate 3D plots of real H wave functions orbitals // Melissa A. Hines, Cornell University, Melissa.Hines@cornell.edu Menu "Macros" "Generate Bohr Orbital" "Generate H Orbital" "Modify Isosurface" End Proc GenerateHOrbital(n, l, m, genPointCloud) variable n, l, m, genPointCloud Prompt n, "n:" Prompt l, "l:" Prompt m, "m:" Prompt genPointCloud, "Generate Point Cloud?", popup "Yes;No" makeWavefunctions(0, 0, n, l, m, genPointCloud==1) End Proc GenerateBohrOrbital(n, amplitude) variable n, amplitude=0.2 make/n=256/o circle_x, circle_y, bohrOrbital_x, bohrOrbital_y; SetScale/I x 0,2*pi,"", circle_x,circle_y,bohrOrbital_x,bohrOrbital_y circle_x = cos(x);circle_y = sin(x) bohrOrbital_x = (1+amplitude*cos(n*x))*cos(x);bohrOrbital_y =(1+amplitude*cos(n*x))*sin(x) if(strlen(WinList("bohrOrbitalGraph", ";","")) < 2) Execute "bohrOrbitalGraph()" endif End Proc ModifyIsosurface(theSurface, larger, factor) variable theSurface, larger, factor=2 Prompt theSurface, "Which isosurface?", popup "Psi;Psi2" Prompt larger, "Which direction?", popup "Larger;Smaller" Prompt factor, "How much?" PauseUpdate variable oldIsoValue, multiplier multiplier = (larger < 2) ? 1/factor : factor if(theSurface < 2) // Modify Psi oldIsoValue = currentIsoValue("GizmoPsi", "posSurface") DoWindow/F GizmoPsi ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={isoValue,oldIsoValue*multiplier} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={isoValue,oldIsoValue*multiplier} else oldIsoValue = currentIsoValue("GizmoPsi2", "psi2Surface") DoWindow/F GizmoPsi2 ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={isoValue,oldIsoValue*multiplier} endif End // Calculate H atom wavefunction using real orbitals defined at // https://en.wikipedia.org/wiki/Atomic_orbital#Real_orbitals Function calcPsi(n, l, m, rr, theta, phi) variable n, l, m, rr, theta, phi if(m < 0) return sqrt(2)*(-1)^m * Rnl(n, l, rr) * imag(sphericalHarmonics(l,-m,theta,phi)) elseif(m > 0) return sqrt(2)*(-1)^m * Rnl(n, l, rr) * real(sphericalHarmonics(l,m,theta,phi)) else return Rnl(n, l, rr) * real(sphericalHarmonics(l,0,theta,phi)) endif End // Calculate H atom radial wavefunction as defined at https://en.wikipedia.org/wiki/Hydrogen_atom#:~:text=The%20normalized%20position%20wavefunctions Function Rnl(n, l, r) variable n, l, r variable out, a0 = 0.529, rho rho = 2*r/n/a0 out = sqrt((2/n/a0)^3*factorial(n - l - 1)/(2 * n * factorial(n + l))) * exp(-rho/2)*(rho)^(l) * LaguerreA(n-l-1, 2*l+1, rho) return out End // This function calculates the radial wavefunction and displays graphs of psi, psi^2, and 4 pi r^2 psi^2. // Three dimensional waves representing psi^2 and positive and negative regions of psi are generated. These // are displayed in Gizmo plots. The isosurfaces may need tweaking to generate a pleasing size. // Finally (if requested) a Monte Carlo algorithm is used to generate a point cloud representing psi. Function makeWavefunctions(pts, range, n, l, m, doMakeCloud) // pts = number of points in sqr box. 75 seems to be a good number. Use 0 to autoscale. // range = Box is defined over the region x, y, z = (-range, range). Use 0 to autoscale. // n, l, m: Usual hydrogenic quantum numbers // doMakeCloud = (0, 1) depending on whether the point cloud should be generated. variable pts, range, n, l, m, doMakeCloud variable i,j,k,xx,yy,zz,rr,rho,phi,theta, psi // Validate the quantum numbers if( (n < 1) || (l >= n) || (l < 0) || (abs(m) > l)) Print "Invalid quantum numbers" return -1 endif // Autosizing if pts == 0 if(pts < 1) pts = 75 endif variable center=floor(pts/2) // Use odd number of points // Autoscaling if range == 0 if(!exists("radialPsi")) make/n=512/o radialPsi, radialPsi2, radialProbability, zero endif wave radialPsi, radialPsi2, radialProbability, zero if(range < 0.01) range = calcRange(150, n, l) // Set a huge range and do a rough graph range = calcRange(range, n, l) // Refine the range endif // Update radial wavefunction SetScale/I x 0,range,"", radialPsi,radialPsi2,radialProbability,zero radialPsi = Rnl(n,l,x) radialPsi2 = radialPsi^2 radialProbability = 4*pi*x^2*radialPsi2 // If the radial graphs are not displayed, display them if(strlen(WinList("radialPsiGraph", ";","")) < 2) Execute "radialPsiGraph()" endif if(strlen(WinList("radialPsi2Graph", ";","")) < 2) Execute "radialPsi2Graph()" endif if(strlen(WinList("radialProbabilityGraph", ";","")) < 2) Execute "radialProbabilityGraph()" endif pts = 2*floor(pts/2) + 1 make/o/n=(pts, pts, pts) ddd_psi2, ddd_psiPos, ddd_psiNeg SetScale/I x -range,range,"", ddd_psi2, ddd_psiPos, ddd_psiNeg SetScale/I y -range,range,"", ddd_psi2, ddd_psiPos, ddd_psiNeg SetScale/I z -range,range,"", ddd_psi2, ddd_psiPos, ddd_psiNeg for(k=0;k<pts;k+=1) zz=range * (k-center)/center for(j=0;j<pts;j+=1) yy=range * (j-center)/center for(i=0;i<pts;i+=1) xx=range * (i-center)/center // compute spherical polar coords rr=sqrt(xx^2 + yy^2 + zz^2) phi=atan2(yy,xx) theta=acos(zz/rr) psi = calcPsi(n, l, m, rr, theta, phi) if(psi > 0) ddd_psiPos[i][j][k] = psi ddd_psiNeg[i][j][k] = 0 else ddd_psiPos[i][j][k] = 0 ddd_psiNeg[i][j][k] = -psi endif ddd_psi2[i][j][k] = psi^2 endfor endfor endfor if(strlen(WinList("GizmoPsi", ";","")) < 2) Execute "GizmoPsi()" endif if(strlen(WinList("GizmoPsi2", ";","")) < 2) Execute "GizmoPsi2()" endif wavestats/q ddd_psiPos DoWindow/F GizmoPsi ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={isoValue,V_max/5} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={isoValue,V_max/5} wavestats/q ddd_psi2 DoWindow/F GizmoPsi2 ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={isoValue,V_max/50} if(doMakeCloud) if(strlen(WinList("GizmoPointCloud", ";","")) > 2) DoWindow/F GizmoPointCloud ModifyGizmo stopUpdates endif makeCloud(n, l, m, range, 30000) if(strlen(WinList("GizmoPointCloud", ";","")) > 2) ModifyGizmo resumeUpdates else Execute "GizmoPointCloud()" endif endif wave W_coef, W_sigma KillWaves/Z W_coef, W_sigma, scaledWave, M_colors End // Calculates an optimal range for the wavefunctions based on the outermost maximum in the radial distribution function Function calcRange(roughRange, n, l) variable roughRange, n, l wave radialPsi, radialPsi2, radialProbability, zero // Set a huge range and do a rough graph SetScale/I x 0,roughRange,"", radialPsi,radialPsi2,radialProbability,zero radialPsi = Rnl(n,l,x) radialPsi2 = radialPsi^2 radialProbability = 4*pi*x^2*radialPsi2 // Fit the max in the radialProbabily to a Gaussian wavestats/Q radialProbability K0 = 0;K1 = V_max;K2 = V_maxLoc; CurveFit/H="1110"/Q gauss radialProbability wave W_coef return ceil(W_coef[2] + 1.5 * W_coef[3]) End // Returns the currently plotted isoValue for a Gizmo isosurface Function currentIsoValue(gizmoName, isoSurfaceName) string gizmoName, isoSurfaceName string matchStr, theStr variable cur = 0 GetGizmo/n=$gizmoName objectList wave/T TW_gizmoObjectList matchStr = "*ModifyGizmo ModifyObject="+isoSurfaceName+",objectType=isoSurface,property={ isoValue,*" do if(stringmatch(TW_gizmoObjectList[cur], matchStr)) theStr = TW_gizmoObjectList[cur] theStr = theStr[strsearch(theStr, "isoValue,", 0)+9,inf] theStr = theStr[0, strlen(theStr)-2] KillWaves TW_gizmoObjectList return str2num(theStr) endif cur += 1 while(cur < numpnts(TW_gizmoObjectList)) KillWaves TW_gizmoObjectList return NaN End Function colorXYZ(n, l, m, xx, yy, zz) variable n, l, m, xx, yy, zz variable rr, phi, theta rr=sqrt(xx^2 + yy^2 + zz^2) phi=atan2(yy,xx) theta=acos(zz/rr) return sign(calcPsi(n, l, m, rr, theta, phi)) End Function acceptOnePnt(n, l, m, xx, yy, zz, numAccepted) variable n, l, m, xx, yy, zz, numAccepted wave pointCloud, colorPnts pointCloud[numAccepted][0] = xx; pointCloud[numAccepted][1] = yy; pointCloud[numAccepted][2] = zz; colorPnts[numAccepted] = colorXYZ(n, l, m, xx, yy, zz) numAccepted += 1 return numAccepted End Function acceptPnts(n, l, m, xx, yy, zz, numAccepted) variable n, l, m, xx, yy, zz, numAccepted // Take advatage of the symmetry of the orbitals to calculate faster numAccepted = acceptOnePnt(n, l, m, xx, yy, zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, -xx, yy, zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, xx, -yy, zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, xx, yy, -zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, -xx, -yy, zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, -xx, yy, -zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, -xx, -yy, -zz, numAccepted) numAccepted = acceptOnePnt(n, l, m, -xx, -yy, -zz, numAccepted) return numAccepted End // This function uses a Monte Carlo algorithm to generate a probabalistic point cloud representing the wavefunction. // The positive and negative components of the wave function are colored red and blue, respectively. Function makeCloud(n, l, m, range, numAccepts) variable n, l, m, range, numAccepts // range = Box is initiallydefined over the region x, y, z = (-range, range). Autoscales after 10% complete variable xx, yy, zz, rr, phi, theta, numTries, numAccepted,magnitude, kMax, maxRange, rescale numAccepts = 8 * ceil(numAccepts/8) make/n=(numAccepts, 3)/o pointCloud pointCloud = 0 make/o/n=(numAccepts) colorPnts numAccepted = 0 numTries = 0 rescale = 1 // Find the maximum value of the wavefuction over the selected range kMax = findMax(n, l, m, numAccepts, range) // The efficiency of the algorithm depends on an optimal setting of the range variable. // We use the input range for 10% of the tries, then reset based on the max value // found to that point maxRange = -1 do xx = enoise(range); yy = enoise(range); zz = enoise(range) rr=sqrt(xx^2 + yy^2 + zz^2) phi=atan2(yy,xx) theta=acos(zz/rr) magnitude = calcPsi(n, l, m, rr, theta, phi)^2 if(abs(magnitude) > abs(enoise(kMax))) numAccepted = acceptPnts(n, l, m, xx, yy, zz, numAccepted) if(rescale && max(xx, yy, zz) > maxRange) maxRange = max(xx, yy, zz) endif endif numTries += 1 if(rescale && numAccepted > 0.1 * numAccepts) range = maxRange * 1.15 rescale = 0 print "New range =", range endif while(numAccepted < numAccepts) // To create a color wave for a scatter in Gizmo ColorTab2Wave Rainbow wave M_colors duplicate/o colorPnts, scaledWave Variable theMin=WaveMin(scaledWave) Variable theMax=WaveMax(scaledWave) Variable nor=(DimSize(M_colors,0)-1)/2 MatrixOP/O scaledWave=nor*(scaledWave-theMin) M_colors/=65535 make/o/n=(numAccepts,4) colorWave=1 // alpha will be 1. colorWave[][0]= M_colors[scaledWave[p]][0] colorWave[][1]= M_colors[scaledWave[p]][1] colorWave[][2]= M_colors[scaledWave[p]][2] // If calculating radialPsi^2, the following line should be approx 1 //print "The integral is ", numAccepted/numTries * 8 * range^3 * kMax // print numTries, numAccepted End Function findMax(n, l, m, numTries, range) variable n, l, m, numTries, range variable theMax = 0, cnt = 0, xx, yy, zz, rr, phi, theta, magnitude do xx = enoise(range); yy = enoise(range); zz = enoise(range) rr=sqrt(xx^2 + yy^2 + zz^2) phi=atan2(yy,xx) theta=acos(zz/rr) magnitude = abs(calcPsi(n, l, m, rr, theta, phi)) if(magnitude > theMax) theMax = magnitude endif cnt += 1 while(cnt < numTries) return theMax End Window GizmoPsi() : GizmoPlot PauseUpdate; Silent 1 // building window... // Building Gizmo 9 window... NewGizmo/W=(35,40,550,500) ModifyGizmo startRecMacro=901 ModifyGizmo scalingOption=63 AppendToGizmo isoSurface=root:ddd_psiPos,name=posSurface ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ surfaceColorType,0} ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ lineColorType,0} ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ lineWidthType,0} ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ fillMode,2} ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ lineWidth,1} ModifyGizmo ModifyObject=posSurface,objectType=isoSurface,property={ isoValue,0.01} ModifyGizmo modifyObject=posSurface,objectType=Surface,property={calcNormals,1} ModifyGizmo setObjectAttribute={posSurface,diffusePos} ModifyGizmo setObjectAttribute={posSurface,shininess0} ModifyGizmo setObjectAttribute={posSurface,specular} AppendToGizmo Axes=boxAxes,name=axes0 ModifyGizmo ModifyObject=axes0,objectType=Axes,property={-1,axisScalingMode,1} ModifyGizmo ModifyObject=axes0,objectType=Axes,property={0,ticks,3} ModifyGizmo ModifyObject=axes0,objectType=Axes,property={1,ticks,3} ModifyGizmo ModifyObject=axes0,objectType=Axes,property={2,ticks,3} ModifyGizmo modifyObject=axes0,objectType=Axes,property={-1,Clipped,0} AppendToGizmo isoSurface=root:ddd_psiNeg,name=negSurface ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ surfaceColorType,0} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ lineColorType,0} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ lineWidthType,0} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ fillMode,2} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ lineWidth,1} ModifyGizmo ModifyObject=negSurface,objectType=isoSurface,property={ isoValue,0.01} ModifyGizmo modifyObject=negSurface,objectType=Surface,property={calcNormals,1} ModifyGizmo setObjectAttribute={negSurface,diffuseNeg} ModifyGizmo setObjectAttribute={negSurface,shininess0} ModifyGizmo setObjectAttribute={negSurface,specular} AppendToGizmo freeAxesCue={0,0,0,1},name=freeAxesCue0 ModifyGizmo modifyObject=freeAxesCue0,objectType=freeAxisCue,property={colorType,0} AppendToGizmo light=Directional,name=light0 ModifyGizmo modifyObject=light0,objectType=light,property={ position,-0.184655,-0.414741,0.891007,0.000000} ModifyGizmo modifyObject=light0,objectType=light,property={ direction,-0.184655,-0.414741,0.891007} ModifyGizmo modifyObject=light0,objectType=light,property={ specular,1.000000,1.000000,1.000000,1.000000} AppendToGizmo attribute diffuse={1,0,0,1,1032},name=diffusePos AppendToGizmo attribute diffuse={1.5259e-05,0.244434,1,1,1032},name=diffuseNeg AppendToGizmo attribute shininess={42,42},name=shininess0 AppendToGizmo attribute specular={1,1,1,1,1032},name=specular ModifyGizmo setDisplayList=0, object=freeAxesCue0 ModifyGizmo setDisplayList=1, object=light0 ModifyGizmo setDisplayList=2, object=posSurface ModifyGizmo setDisplayList=3, object=negSurface ModifyGizmo autoscaling=1 ModifyGizmo currentGroupObject="" ShowTools ModifyGizmo showInfo ModifyGizmo infoWindow={551,31,1185,418} ModifyGizmo SETQUATERNION={0.000000,-0.000000,0.000000,1.000000} ModifyGizmo endRecMacro Execute/Q/Z "SetWindow kwTopWin sizeLimit={46,234,inf,inf}" // sizeLimit requires Igor 7 or later EndMacro Window GizmoPsi2() : GizmoPlot PauseUpdate; Silent 1 // building window... // Building Gizmo 9 window... NewGizmo/W=(213,605,728,1065) ModifyGizmo startRecMacro=901 ModifyGizmo scalingOption=63 AppendToGizmo isoSurface=root:ddd_psi2,name=psi2Surface ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ surfaceColorType,0} ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ lineColorType,0} ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ lineWidthType,0} ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ fillMode,2} ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ lineWidth,1} ModifyGizmo ModifyObject=psi2Surface,objectType=isoSurface,property={ isoValue,0.000225374} ModifyGizmo modifyObject=psi2Surface,objectType=Surface,property={calcNormals,1} ModifyGizmo setObjectAttribute={psi2Surface,diffuse} ModifyGizmo setObjectAttribute={psi2Surface,specular} ModifyGizmo setObjectAttribute={psi2Surface,shininess} AppendToGizmo freeAxesCue={0,0,0,1},name=freeAxesCue0 ModifyGizmo modifyObject=freeAxesCue0,objectType=freeAxisCue,property={colorType,0} AppendToGizmo light=Directional,name=light0 ModifyGizmo modifyObject=light0,objectType=light,property={ position,0.294889,0.694714,0.656059,0.000000} ModifyGizmo modifyObject=light0,objectType=light,property={ direction,0.294889,0.694714,0.656059} ModifyGizmo modifyObject=light0,objectType=light,property={ specular,1.000000,1.000000,1.000000,1.000000} AppendToGizmo attribute diffuse={1,0.250019,0.250019,1,1032},name=diffuse AppendToGizmo attribute specular={1,1,0,1,1032},name=specular AppendToGizmo attribute shininess={30,30},name=shininess ModifyGizmo setDisplayList=0, object=freeAxesCue0 ModifyGizmo setDisplayList=1, object=light0 ModifyGizmo setDisplayList=2, object=psi2Surface ModifyGizmo setDisplayList=3, opName=clearColor0, operation=clearColor, data={1,1,1,1} ModifyGizmo autoscaling=1 ModifyGizmo currentGroupObject="" ShowTools ModifyGizmo showInfo ModifyGizmo infoWindow={782,750,1405,1094} ModifyGizmo SETQUATERNION={0.000000,0.000000,0.000000,1.000000} ModifyGizmo endRecMacro Execute/Q/Z "SetWindow kwTopWin sizeLimit={46,234,inf,inf}" // sizeLimit requires Igor 7 or later EndMacro Window GizmoPointCloud() : GizmoPlot PauseUpdate; Silent 1 // building window... // Building Gizmo 9 window... NewGizmo/W=(947,721,1512,1219) ModifyGizmo startRecMacro=901 ModifyGizmo scalingOption=63 AppendToGizmo Scatter=root:pointCloud,name=thePoints ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ scatterColorType,1} ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ markerType,0} ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ sizeType,0} ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ rotationType,0} ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ Shape,2} ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ size,0.05} ModifyGizmo ModifyObject=thePoints,objectType=scatter,property={ colorWave,root:colorWave} AppendToGizmo freeAxesCue={0,0,0,1},name=freeAxesCue0 ModifyGizmo modifyObject=freeAxesCue0,objectType=freeAxisCue,property={colorType,0} ModifyGizmo setDisplayList=0, object=freeAxesCue0 ModifyGizmo setDisplayList=1, object=thePoints ModifyGizmo autoscaling=1 ModifyGizmo currentGroupObject="" ShowTools ModifyGizmo showInfo ModifyGizmo infoWindow={804,539,1398,783} ModifyGizmo SETQUATERNION={-0.080336,0.084591,0.010790,0.993114} ModifyGizmo endRecMacro Execute/Q/Z "SetWindow kwTopWin sizeLimit={46,234,inf,inf}" // sizeLimit requires Igor 7 or later EndMacro Window radialPsiGraph() : Graph PauseUpdate; Silent 1 // building window... Display /W=(4,523,399,731) radialPsi,zero ModifyGraph gFont="Helvetica" ModifyGraph lStyle(zero)=1 ModifyGraph rgb=(0,0,0) ModifyGraph mirror=2 ModifyGraph nticks(left)=0 ModifyGraph font="Helvetica" ModifyGraph fSize=12 ModifyGraph lblMargin(left)=11 ModifyGraph lblLatPos(left)=-1 ModifyGraph btLen=4 Label left "ψ" Label bottom "\\f02r\\f00 (Å)" EndMacro Window radialPsi2Graph() : Graph PauseUpdate; Silent 1 // building window... Display /W=(0,771,395,979) radialPsi2 ModifyGraph gFont="Helvetica" ModifyGraph rgb=(0,0,0) ModifyGraph mirror=2 ModifyGraph nticks(left)=0 ModifyGraph font="Helvetica" ModifyGraph fSize=12 ModifyGraph lblMargin(left)=10 ModifyGraph btLen=4 Label left "ψ\\S2\\M" Label bottom "\\f02r\\f00 (Å)" EndMacro Window radialProbabilityGraph() : Graph PauseUpdate; Silent 1 // building window... Display /W=(1,1015,396,1223) radialProbability ModifyGraph gFont="Helvetica" ModifyGraph rgb=(0,0,0) ModifyGraph mirror=2 ModifyGraph nticks(left)=0 ModifyGraph font="Helvetica" ModifyGraph fSize=14 ModifyGraph lblMargin(left)=11 ModifyGraph btLen=4 Label left "4 π \\f02r\\f00\\S2\\M ψ\\S2\\M" Label bottom "\\f02r\\f00 (Å)" EndMacro Window bohrOrbitalGraph() : Graph PauseUpdate; Silent 1 // building window... Display /W=(35,520,424,903) circle_y vs circle_x AppendToGraph bohrOrbital_y vs bohrOrbital_x ModifyGraph gFont="Helvetica",height={Plan,1,left,bottom} ModifyGraph lStyle(circle_y)=1 ModifyGraph rgb=(0,0,0) ModifyGraph nticks=0 ModifyGraph font="Helvetica" ModifyGraph axThick=0 EndMacro
