User interface for naming and storing a wave
A little modal dialog to ask the user where to store a wave. Copy the code into a new procedure window and execute the following:
make foo
SaveWave#SaveWaveUI(foo)
#pragma rtGlobals=3
#pragma ModuleName=SaveWave
#pragma version = 1.21
static function/WAVE SaveWaveUI(wave w, [string basename, int overwrite])
overwrite = ParamIsDefault(overwrite) ? 1 : overwrite // default is to allow user to overwrite a wave
if (ParamIsDefault(basename))
basename = NameOfWave(w)
if (cmpstr(basename, "_free_") == 0)
basename = "wave"
DoWindow/K SaveWaveDialog
GetMouse
variable left, top, right, bottom
left = pixel2cpu(V_left) - 50
top = pixel2cpu(V_top) - 50
right = left + 220
bottom = top + 150
NewPanel/K=1/W=(left,top,right,bottom)/N=SaveWaveDialog as "Save Wave"
SetVariable svName,pos={25,20},size={157,14},title="Wave Name", userdata(base) = basename
SetVariable svName,value=_STR:UniqueName(basename, 1, 0), fsize=12, Proc=SaveWave#SaveWaveSetVars
PopupMenu popFolder,pos={25,50},size={157,14},title="Data Folder", fsize=12
PopupMenu popFolder,value=#"GetDataFolder(0)", userdata(folder)=GetDataFolder(1), Proc=SaveWave#SaveWavePopups
Button btnCancel,pos={40,100},size={55,20},title="Cancel", Proc=SaveWave#SaveWaveButtons
Button btnDoIt,pos={130,100},size={50,20},title="Do It", Proc=SaveWave#SaveWaveButtons, userdata=num2str(overwrite)
PauseForUser SaveWaveDialog
wave/Z/WAVE w_savewave
if (WaveExists(w_savewave))
wave/Z saved = w_savewave[0]
string strPathToNewWave = GetWavesDataFolder(saved, 2)
KillWaves/Z saved
Duplicate/O w $strPathToNewWave /wave=saved
KillWaves w_savewave
return saved
return $""
static function SaveWavePopups(STRUCT WMPopupAction &s) : PopupMenuControl
if (s.eventCode != 3)
string strFolder = StringFromList(0, SelectFolder(s.popStr))
if (strlen(strFolder))
PopupMenu popFolder, win=$s.win, userdata(folder)=strFolder
PopupMenu popFolder, win=$s.win, value=#"SaveWave#GetSelectedFolder(0)"
CheckNameSetvar()
static function SaveWaveButtons(STRUCT WMButtonAction &s) : ButtonControl
if (s.eventcode != 2)
strswitch (s.ctrlName)
case "btnDoIt":
int overwrite = str2num(s.userdata)
ControlInfo/W=$s.win svName
if (!overwrite && exists(GetSelectedFolder(1)+PossiblyQuoteName(s_value)))
DoAlert 0, s_value + " exists."
KillWaves/Z $GetSelectedFolder(1)+PossiblyQuoteName(s_value)
wave/Z w = $GetSelectedFolder(1)+PossiblyQuoteName(s_value)
if (WaveExists(w))
DoAlert 0, s_value + " exists and is in use, cannot overwrite."
Make/O/N=0 $GetSelectedFolder(1)+PossiblyQuoteName(s_value) /wave=w
Make/O/WAVE w_savewave = {w}
case "btnCancel" : // Cancel or Do It
DoWindow/K $s.win
break
endswitch
static function SaveWaveSetVars(STRUCT WMSetVariableAction &s)
if (s.eventCode < 0) // excludes Igor8 eventcodes -2 and -3
if (cmpstr(s.ctrlName, "svName") == 0)
CheckNameSetvar()
static function CheckNameSetvar()
ControlInfo/W=SaveWaveDialog svName
if (strlen(S_Value) == 0)
S_Value = UniqueName(GetUserData("SaveWaveDialog", "svName", "base"), 1, 0)
SetVariable svName win=SaveWaveDialog, value=_STR:S_Value
if (exists(GetSelectedFolder(1) + S_Value))
SetVariable svName win=SaveWaveDialog, valueBackColor=(0xFFFF,0,0)
SetVariable svName win=SaveWaveDialog, valueBackColor=0
static function/T GetSelectedFolder(int fullpath)
string strFolder = GetUserData("SaveWaveDialog", "popFolder", "folder")
return SelectString(fullpath, ParseFilePath(0, strFolder, ":", 1, 0), strFolder)
static function/T SelectFolder(string selection)
CreateBrowser/M Prompt="Select Data Folder"
ModifyBrowser/M showWaves=0, showVars=0, showStrs=0
ModifyBrowser/M ShowInfo=0, showPlot=0
ModifyBrowser/M select=selection
ModifyBrowser/M showModalBrowser
if (V_Flag == 0)
return "" // User cancelled
return S_BrowserList
static function pixel2cpu(variable pixel, [string win])
variable expansion = ParamIsDefault(win) ? 1 : PanelResolution(win)/PanelResolution("")
return (ScreenResolution > 96 ? pixel * 72 / ScreenResolution : pixel) / expansion
Tony,
I gave this a quick test and found that if the "Data Folder" popup menu is clicked, the Data Browser opens. After selecting a folder and clicking "Ok", the browsers closes and immediately opens a second time. Clicking "Ok" a second time the wave is saved in the selected directory.
This is with a couple of directories existing in the root directory. IP9.03B01 on Win10.
Jeff
September 5, 2023 at 01:52 pm - Permalink
Ah, I see.
The intention was to allow either mouse or keyboard input. In testing on mac it worked OK, except that I cannot use tab to cycle through the controls in the panel, so keyboard input doesn't work. In Windows, on the other hand, a mouse click produces both 'hovering' and 'control received keyboard focus' events, resulting in the double-modal-browser behaviour. I've fixed it by ignoring the 'control received keyboard focus' event.
I used a popup control because it provides a visual indication that it should be clicked to select. A button could also be used for the same purpose, it would look a bit like the built-in make waves dialog.
September 6, 2023 at 02:49 am - Permalink
The WaveSelectorWidget and HierarchicalListWidget use a button with a downward-pointing trace marker as the menu indicator, like this: \\JR(no selection) \\W623. The \\W623 is the marker, and \\JR is for right-justification so the marker is at the right edge of the button.
To get the full tab navigation on a Mac, in the Keyboard settings, Shortcuts tab, turn on the All Control radio button under the Full keyboard access title near the bottom. At least on OS 10.14 :)
September 6, 2023 at 10:51 am - Permalink
No more Doppel-browser - it opens only once now.
I was looking into creating the modal browser with the "New Data Folder" button intact (Because I would forget to create a new folder before invoking your function.), but that doesn't seem possible. Or am I missing something?
September 7, 2023 at 12:11 pm - Permalink
I have updated the snippet with a new version that works with free waves. This means that you can provide the user with a free wave and the user saves a copy of the wave with a name/location of their choice in the current experiment. I couldn't find a simple way to allow the user to create a new data folder as part of the dialog.
May 6, 2024 at 02:41 am - Permalink
