Custom fill pattern, SetDrawEnv
This probably can't be done, but maybe someone has a work-around. I have the following drawn rectangle with colored pattern fill mode:
Window Graph0() : Graph
PauseUpdate; Silent 1 // building window...
Display /W=(802,481,1324,877)
ShowTools/A
SetDrawLayer UserFront
SetDrawEnv fillpat= 7,fillfgc= (19675,39321,1),fillbgc= (49151,53155,65535)
DrawRect 0.2,0.2,0.8,0.8
EndMacroI'd like to modify the diagonal stroke pattern, such that every third or fourth stroke is not green but has a different color (e.g. orange). The important aspect is that I need a third color in the pattern. I thought I could change this afterwards in Illustrator (when exported as pdf), but it appears as single object which can not be tweaked in that way.
Any ideas are highly appreciated!
I was going to suggest overlaying different patters, but apparently patterns cannot be scaled or otherwise modified in any way. Would using a wave work for your case instead of a drawn pattern? You could create a 2D matrix with your desired pattern, color it accordingly and then add a sub-graph to mimic the desired pattern. For example, here is a simple way to create a diagonal pattern using a wave:
Here, K0 is the distance in data points and K1 is the line thickness in data points. This approach is a bit tedious, but would avoid summoning Illustrator after each export.
August 13, 2026 at 07:27 am - Permalink
Thanks chozo. In the end I drew over some strokes in Illustrator. Not the most elegant approach but effective.
August 17, 2026 at 04:15 am - Permalink
