Delete graph macro
Hi all,
I have a file with a fairly large number of graph macros, some of which are old and which i no longer want in the environment. Is there a way to remove graph macros?
Thanks in advance
hrodstein
You can only remove macros manually by editing the procedure window.
Choose Windows->Procedure Windows->Procedure Window to display the procedure window.
You can find graph macros by choosing Edit->Find and searching for ": Graph" (without the quotes and with one space after the colon.
Alternatively you can click the Windows menu again, go down to Graph Macros, press the option key (Macintosh) or Alt key (Windows), and choose a macro from the menu to jump to it in the procedure window.
